Salta al contenuto principale
How to Realign a Guitar Neck
Mahbub Hasan
Mahbub Hasan e un altro collaboratore
Ultimo aggiornamento il December 15, 2021
25 - 35 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to realign a guitar neck by adjusting the truss rod. The guitar used in this guide is a Dean acoustic guitar, but this procedure may be applied to different models.
The neck can become misaligned due to thermal expansion and can happen when the guitar is not stored properly. Playing a guitar with a misaligned neck may result in buzzing sounds and can be difficult to play comfortably.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Realign a Guitar Neck, How to Realign a Guitar Neck: passo 1, immagine 1 di 2 How to Realign a Guitar Neck, How to Realign a Guitar Neck: passo 1, immagine 2 di 2
    • Place the guitar on a flat surface.
  2. How to Realign a Guitar Neck: passo 2, immagine 1 di 2 How to Realign a Guitar Neck: passo 2, immagine 2 di 2
    • Use the tuning pegs to loosen the strings.
  3. How to Realign a Guitar Neck: passo 3, immagine 1 di 2 How to Realign a Guitar Neck: passo 3, immagine 2 di 2
    • Place the alignment key on the truss rod.
    • The alignment key should fit perfectly on the truss rod in order to align properly.
  4. How to Realign a Guitar Neck: passo 4, immagine 1 di 2 How to Realign a Guitar Neck: passo 4, immagine 2 di 2
    • Gently turn the tuning key clockwise to increase the distance between the bridge and strings, or counter-clockwise to reduce the distance between the bridge and strings.
    • Twisting the key too hard might break the bridge. The twist should be smooth.
    • After one twist at the rod, be sure to check the bridge to see if it will need more aligning.
  5. How to Realign a Guitar Neck: passo 5, immagine 1 di 1
    • Tighten the strings up again using the tuning pegs.
    • Do not over tighten the strings; doing so can cause them to break.
  6. How to Realign a Guitar Neck: passo 6, immagine 1 di 2 How to Realign a Guitar Neck: passo 6, immagine 2 di 2
    • Tune the guitar using a tuner.
    • Some Dean guitars have a built-in tuner.
Linea Traguardo
Mahbub Hasan
Membro da: 09/19/21
133 Reputazione
1 Guida realizzata
1Commento della guida
This is all wrong.
What's being done here is tightening the truss rod, which does NOT align the neck. You cannot change the distance between the bridge and the strings.
You do not want to fool with the truss rod unless you understand what it does and how to tell that you're doing it correctly, and this "guide" does not even begin to explain any of that.
Dan Gellert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,079
