Salta al contenuto principale
Questa guida ha delle modifiche più recenti. Passa all'ultima versione non verificata.
How to Perform a Battery Cycle Reset
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl e 3 altri collaboratori
Ultimo aggiornamento il May 19, 2025
2 - 5 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to perform a battery cycle reset on your Samsung phone or tablet. You should perform this reset whenever you change the battery for your Samsung device.
  • Supported S Phones: S20, S20+, S20 Ultra, S21, S21+, S21 Ultra, S21 FE, S22, S22+, S22 Ultra, S23, S23+, S23 Ultra, S23 FE, S24, S24+, S24 Ultra
  • Supported A Phones: A54
  • Supported Fold Phones: Z Fold5
  • Supported Flip Phones: Z Flip5
  • Supported S Tablets: Tab S7+, Tab S9, Tab S9+, Tab S9 Ultra, Tab S9 FE, Tab S9 FE+
  • Unsupported S Phones: S20 FE, S24 FE, S25, S25+, S25 Ultra
  • Unsupported Note Phones: Note20, Note20 Ultra
  • Unsupported Fold Phones: Z Fold1, Fold2, Fold3, Fold4, Fold6
  • Unsupported Flip Phones: Z Flip1, Flip2, Flip3, Flip4, Flip6
  • Unsupported Tablets: Tab S7, Tab S7 FE, Tab S8, Tab S8+, Tab S8 Ultra, Tab S10+, Tab S10 Ultra
For more information, refer to the Samsung Self-Repair document.
Note: the device used is a Samsung Galaxy Tab S7+, but the procedure is identical across all Samsung devices.
Note: Samsung account required.
  1. How to Perform a Battery Cycle Reset, Download the app: passo 1, immagine 1 di 3 How to Perform a Battery Cycle Reset, Download the app: passo 1, immagine 2 di 3 How to Perform a Battery Cycle Reset, Download the app: passo 1, immagine 3 di 3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Perform a Battery Cycle Reset, Install the app: passo 2, immagine 1 di 2 How to Perform a Battery Cycle Reset, Install the app: passo 2, immagine 2 di 2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Perform a Battery Cycle Reset, Rename the app: passo 3, immagine 1 di 3 How to Perform a Battery Cycle Reset, Rename the app: passo 3, immagine 2 di 3 How to Perform a Battery Cycle Reset, Rename the app: passo 3, immagine 3 di 3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: passo 4, immagine 1 di 3 How to Perform a Battery Cycle Reset: passo 4, immagine 2 di 3 How to Perform a Battery Cycle Reset: passo 4, immagine 3 di 3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: passo 5, immagine 1 di 2 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: passo 5, immagine 2 di 2
    • Select the Galaxy Cal app.
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: passo 6, immagine 1 di 1
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: passo 7, immagine 1 di 2 How to Perform a Battery Cycle Reset, Select the procedure: passo 7, immagine 2 di 2
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: passo 8, immagine 1 di 3 How to Perform a Battery Cycle Reset: passo 8, immagine 2 di 3 How to Perform a Battery Cycle Reset: passo 8, immagine 3 di 3
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
Linea Traguardo
Altre 13 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
166.905 Reputazione
769 Guide realizzate
iFixit Membro di iFixit
Staff
121 Membri
20.385 Guide realizzate
39Commenti sulla guida
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - Replica
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 109
Ultimi 7 Giorni: 995
Ultimi 30 Giorni: 3,837
Tutti i Tempi: 83,606
