Salta al contenuto principale
How to Open the Logitech G703
Dominik Schnabelrauch
Ultimo aggiornamento il June 13, 2023
15 - 25 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to open a Logitech G703 wireless gaming mouse for cleaning or repair.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Open the Logitech G703, Turn off the mouse: passo 1, immagine 1 di 2 How to Open the Logitech G703, Turn off the mouse: passo 1, immagine 2 di 2
    • Before you begin, flip the mouse's power switch into the red OFF position.
  2. How to Open the Logitech G703, Heat the mouse foot: passo 2, immagine 1 di 1
    • If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and apply it to the bottom mouse foot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage.
  3. How to Open the Logitech G703, Separate the mouse foot adhesive: passo 3, immagine 1 di 3 How to Open the Logitech G703, Separate the mouse foot adhesive: passo 3, immagine 2 di 3 How to Open the Logitech G703, Separate the mouse foot adhesive: passo 3, immagine 3 di 3
    • Slide an opening pick under an edge of the bottom mouse foot.
    • Go slowly, and make sure the pick is underneath both the foot and its adhesive layer if you want to reuse the foot. It's easy to separate the foot from its adhesive.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide the pick under the rest of the foot until you can lift it off the mouse.
    • Remove the foot.
    • Repeat the procedure to remove the top mouse foot.
  4. How to Open the Logitech G703, Clean off the old adhesive: passo 4, immagine 1 di 3 How to Open the Logitech G703, Clean off the old adhesive: passo 4, immagine 2 di 3 How to Open the Logitech G703, Clean off the old adhesive: passo 4, immagine 3 di 3
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Peel the adhesive off.
    • Before installing new feet or reinstalling old ones, wipe away any adhesive residue from the mouse with a lint-free cloth and high-concentration isopropyl alcohol.
  5. How to Open the Logitech G703, Remove the case screws: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 5.4 mm screws securing the two halves of the mouse together.
  6. How to Open the Logitech G703, Start separating the mouse halves: passo 6, immagine 1 di 2 How to Open the Logitech G703, Start separating the mouse halves: passo 6, immagine 2 di 2
    • There are clips in front of the mouse wheel holding the two halves together. It is easiest to pull the halves apart at the back of the mouse and to open the clips in the front afterwards to separate them.
    • Don't completely separate the two halves yet—they're still tethered together by a delicate cable.
    • Grasp the mouse case at the back and pull the two halves apart slightly, so there's a gap at the back of the mouse.
  7. How to Open the Logitech G703, Unclip the mouse case: passo 7, immagine 1 di 2 How to Open the Logitech G703, Unclip the mouse case: passo 7, immagine 2 di 2
    • The front of the mouse is held together by plastic clips. They can be particularly stubborn and may require some force to pull apart. Apply steady, slowly increasing pressure to force the halves away from each other.
    • Insert a spudger into the small gap between the top and the bottom mouse case right above the charging port.
    • Pry open the mouse clips by tilting the spudger upwards to separate the two mouse halves.
    • The mouse halves are still tethered together by a delicate cable.
  8. How to Open the Logitech G703, Disconnect the interconnect cable: passo 8, immagine 1 di 3 How to Open the Logitech G703, Disconnect the interconnect cable: passo 8, immagine 2 di 3 How to Open the Logitech G703, Disconnect the interconnect cable: passo 8, immagine 3 di 3
    • Use the flat end of a spudger to gently lift the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
    • Slide the interconnect cable out of its socket on the motherboard.
  9. How to Open the Logitech G703, Remove the top half of the mouse: passo 9, immagine 1 di 1
    • Remove the top half of the mouse.
Conclusione
Altre 13 persone hanno completato questa guida.
Membro da: 11/23/16
233.729 Reputazione
682 Guide realizzate
iFixit Membro di iFixit
Staff
120 Membri
20.220 Guide realizzate
5Commenti sulla guida
Thanks for this guide :)
It helped me diagnose the issue in my mouse and order the correct replacement parts.
One thing that I did find helpful is removing the ribbon cable before trying to unclip the top half
Duncan Sterken - Replica
How do you glue back the old adhesive feet?
Javi Alarcia - Replica
Where can I buy a replacement ribbon cable?
Emanuel Ibarra - Replica
worthless mouse. I tried every instruction out there and nothingg worked. I threw mine in the garbage and tot a new mouse.
William Proveaux - Replica
Simple disassembly guide that helped me out! I've had good luck with Logitech mice in the recent past with the adhesive pads on the bottom. I just set them aside sticky side up and had no problem sticking them back on. The clip in the front did give me some issue though.
Joe Willis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 105
Ultimi 30 Giorni: 457
Tutti i Tempi: 26,810
