Salta al contenuto principale
How to Install Toilet Seat Stabilizers
Lori Bagala-De Marco
Lori Bagala-De Marco e un altro collaboratore
Ultimo aggiornamento il May 24, 2024
15 - 20 minuti
Facile
Introduzione
Vai al passo 1
This guide shows how to install toilet seat stabilizers. Toilet seats often do not remain stable despite tightening the seat bolts. Loose toilet seats can pose a danger to the elderly or anyone with balance difficulties. We will show you how to install seat stabilizers to ensure your safety. Installing toilet seat stabilizers is a simple process that most people can do at home.
  1. How to Install Toilet Seat Stabilizers, How to Install Toilet Seat Stabilizers: passo 1, immagine 1 di 1
    • Make sure the toilet and the toilet seat are clean and dry.
    • Put the toilet seat in an upright position.
    • Loop the rubber band through the round screw hole in one of the safety bumpers.
  2. How to Install Toilet Seat Stabilizers: passo 2, immagine 1 di 2 How to Install Toilet Seat Stabilizers: passo 2, immagine 2 di 2
    • Place the longest flat side of the safety bumper against the bottom of the toilet seat adjacent to any existing bumper.
    • Loop the rubber band around the toilet seat so the safety bumper sits flush and securely against the seat.
    • The perpendicular piece of the safety bumper should fit just inside the toilet bowl when the toilet seat is fully down.
    • Confirm the placement of the safety bumper and adjust it if necessary. Return the seat to the upright position.
  3. How to Install Toilet Seat Stabilizers: passo 3, immagine 1 di 1
    • Using a 5/64” drill bit, drill a hole in the center of the slotted hole, not more than ⅜ inch deep.
    • Do not drill through the toilet seat.
  4. How to Install Toilet Seat Stabilizers: passo 4, immagine 1 di 1
    • Place one of the screws into the drilled hole and use the screwdriver to tighten the screw only halfway in to allow for adjustments.
    • Remove the rubber band.
    • Repeat mounting instructions on the other side of the toilet seat.
    • Lower the seat and check that safety bumpers are aligned on both sides.
  5. How to Install Toilet Seat Stabilizers: passo 5, immagine 1 di 2 How to Install Toilet Seat Stabilizers: passo 5, immagine 2 di 2
    • Use the screwdriver to tighten both slotted screws.
    • Screw the anchor screws into round holes.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 542
