Salta al contenuto principale
How to Force Restart an iPhone 4S
Evan Noronha
Evan Noronha e 2 altri collaboratori
Ultimo aggiornamento il 13 ago 2017
30 secondi
Molto facile
Introduzione
Vai al passo 1
Use this guide to force restart your iPhone 4S when it is frozen and not responding. Force restarts are very simple and require no tools.
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: passo 1, immagine 1 di 2 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: passo 1, immagine 2 di 2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
    Helpful.......it's working. PTL!!!! It's saved.
    Renee A Watson - Replica
    i cant use my power button because it cant function
    Elsa Cagampang - Replica
    please help me.. how can i restart my phone using emergency call beacause the power button of my cp it cannot function.
    Its not workiing because the home button of my phone is malfunctioned
    Niranjan Manoj - Replica
    Bonjour
    Le logo Apple est là mais, la restauration des applications est impossible.
    Que faire ?
    D'avance merci !
    Fatiou Assani Badarou - Replica
  2. How to Force Restart an iPhone 4S: passo 2, immagine 1 di 2 How to Force Restart an iPhone 4S: passo 2, immagine 2 di 2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do you do if the apple doesn’t appear?
    David Wilmot - Replica
Linea Traguardo
Altre 237 persone hanno completato questa guida.
Evan Noronha
Membro da: 02/05/15
226.850 Reputazione
168 Guide realizzate
23Commenti sulla guida
what if our power butoon is broken/
Autumn Harris - Replica
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers -
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - Replica
Great Instructions! Thank you.
georgiaruocco - Replica
bravo c superbe
perdereau - Replica
my iphone is not getting started. it turns on when i plug in the cable but still stucks in the iphone logo.
Tarif Hasan - Replica
Thank you Heather Powers! You must be one of the geniuses ;p
Susanne Vierbergen - Replica
Thank you so much my phone is now working it has been off, the past 4 days but its now finally working 100% :-)
Asia Kakorokoro - Replica
not helpful whatso ever dont listen to him he is a lieer
thomas andrews - Replica
soz he dosent reall suck and lie
can anyone help me my iphone wont go to the main home screen i turn my phone on and its shows itunes symbol and charger how do i removve that
Dawn Henry - Replica
Thank you it brot my iphone 4S back, great
genebrn - Replica
My home button is broken.
Ruby Magdalene Acol-Acol - Replica
Please tell me what comes next. I get logo then what do I do
Billie kennedy - Replica
you just wait until your homescreen appears :3
YTKatten -
Works fine. Online instructions are well illustrated, but it would be helpful to WARN potential users that the little screws holding the battery clip are really tough to orient and re-insert. Be sure to work on a clean white surface; so, if they fall off the driver they don’t wind up on the floor. You’ll never find them there. I was lucky, they stuck to the magnetic tool that came with the kit.
Robert Vrijenhoek - Replica
IT all went smoothly for me, but my own unsteady hand was my worst enemy (I am 65+), and a constant fear that I would drop one of those nearly invisible screws on the carpet below.
Gary Liebisch - Replica
i didnt put the display in the perfect way in the phone, had to reopen it again, but put too much pressure onto it and i think i killed some cable?
its not doing anything again so..
is there anything i can do?
maximmerle - Replica
Merhaba , iPhone 4s şarja takıldığında apple logosu geliyor biraz durup sonra gidiyor böyle döngü ediyor ve telefon açılmıyor
oyun ustası 2004.2005 - Replica
Çözüm nedir acaba?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 151
Tutti i Tempi: 87,144
