Salta al contenuto principale
How to Fix a Loose Bath Tub Faucet Handle
Vincent Wen
Vincent Wen e un altro collaboratore
Ultimo aggiornamento il August 28, 2023
10 - 20 minuti
Facile
Introduzione
Vai al passo 1
After using a bath faucet for a long period of time, the handle can become loose and when you want to close the water it doesn't close properly. This can lead to leaks until you deal with the issue.
This guide instructs you how to fix the loose handle and will help you avoid unnecessary leaks and wasting water. In addition, you may be able to avoid purchasing a new faucet.
  1. How to Fix a Loose Bath Tub Faucet Handle, How to Fix a Loose Bath Tub Faucet Handle: passo 1, immagine 1 di 2 How to Fix a Loose Bath Tub Faucet Handle, How to Fix a Loose Bath Tub Faucet Handle: passo 1, immagine 2 di 2
    • Turn off the central water valve. It is typically located outside.
    • Use a spudger or your fingers to remove the rubber plug, near the center of the faucet handle.
  2. How to Fix a Loose Bath Tub Faucet Handle: passo 2, immagine 1 di 2 How to Fix a Loose Bath Tub Faucet Handle: passo 2, immagine 2 di 2
    • Use a screwdriver to remove the screw inside the handle.
  3. How to Fix a Loose Bath Tub Faucet Handle: passo 3, immagine 1 di 2 How to Fix a Loose Bath Tub Faucet Handle: passo 3, immagine 2 di 2
    • Remove the faucet handle.
  4. How to Fix a Loose Bath Tub Faucet Handle: passo 4, immagine 1 di 2 How to Fix a Loose Bath Tub Faucet Handle: passo 4, immagine 2 di 2
    • Use a screwdriver to tighten the screw at the top of the internals of the handle.
    • When finished reassembling, turn on the water to check if the faucet handle still feels loose. If so, the faucet may need to be replaced.
Conclusione
To reassemble your device, follow these instructions in reverse order. I believe this guide is needed because at our house we were forced to change the whole faucet. However, after some research, we found out this problem was only a 10-minute fix. This problem can cause more unnecessary trash because many times people will end up buying new facets. I was hoping that this fix idea could lead to fewer faucets in the trash.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 121
Tutti i Tempi: 2,765
