Salta al contenuto principale
How to Fix a Feather Cat Toy
Isabella Markell
Isabella Markell e 3 altri collaboratori
Ultimo aggiornamento il 5 giu 2024
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
This guide will outline how to fix a feather cat toy that your cat has destroyed. This can happen when your cat gets too aggressive with the feathers on the end of the string, leaving the toy unusable.
Using tools you will most likely already own, repairing the toy yourself will be cheaper than buying a new one.
  1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: passo 1, immagine 1 di 2 How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: passo 1, immagine 2 di 2
    • Slide a crimp onto the cat toy's line.
    • Thread the line through the ring of the key clasp.
    • You should have a small loop formed at the end of the line.
  2. How to Fix a Feather Cat Toy: passo 2, immagine 1 di 2 How to Fix a Feather Cat Toy: passo 2, immagine 2 di 2
    • Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
    • Use your crimping tool or pliers in order to secure the crimp.
  3. How to Fix a Feather Cat Toy: passo 3, immagine 1 di 1
    • Apply super glue to any cracks visible on the feather capsule for maximum security.
    • Let the feather capsule piece dry entirely before proceeding to the next step.
  4. How to Fix a Feather Cat Toy: passo 4, immagine 1 di 1
    • Use regular glue to fill the inner portion of the feather capsule.
    • Fill it up only halfway in order to leave enough space for feathers.
  5. How to Fix a Feather Cat Toy: passo 5, immagine 1 di 2 How to Fix a Feather Cat Toy: passo 5, immagine 2 di 2
    • Individually insert the quill of each feather into the capsule.
    • Work quickly so that the glue doesn’t dry and cause the feathers to stick in the wrong direction.
  6. How to Fix a Feather Cat Toy: passo 6, immagine 1 di 1
    • Press down on the clasp lever to open up the hinge.
    • Slide the loop on the feather connector into the clasp to reconnect the toy.
Conclusione
Repeat the instructions in this guide every time your cat breaks their toy!
Isabella Markell
Membro da: 04/24/24
148 Reputazione
1 Guida realizzata
UC Davis, Team 1-6, Whithaus Spring 2024 Membro di UC Davis, Team 1-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G6
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 216
