Salta al contenuto principale
How To Remove Bike Rust With Lemon Juice
Eric Robinson
Eric Robinson e 4 altri collaboratori
Ultimo aggiornamento il 2 ago 2019
15 - 30 minuti
Facile
Introduzione
Vai al passo 1
This step-by-step guide will provide the user with a quick and easy way to remove that unappealing rust that builds up on exposed metal parts on bicycle brakes. Unwanted rust can inhibit the proper function of your brakes. This guide can be used on a variety of bike brakes which has exposed metal parts and is susceptible to rust.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: passo 1, immagine 1 di 2 How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: passo 1, immagine 2 di 2
    • Put on Latex gloves
  2. How To Remove Bike Rust With Lemon Juice: passo 2, immagine 1 di 1
    • Generously apply the lime juice onto steel wool
    • Keep the lime juice out of eyes and any open wounds due to the acidic qualities of the lime juice
  3. How To Remove Bike Rust With Lemon Juice: passo 3, immagine 1 di 3 How To Remove Bike Rust With Lemon Juice: passo 3, immagine 2 di 3 How To Remove Bike Rust With Lemon Juice: passo 3, immagine 3 di 3
    • Vigorously rub the steel wool with lime juice on the rusty parts of the brakes
  4. How To Remove Bike Rust With Lemon Juice: passo 4, immagine 1 di 1
    • Wipe off the excess lime juice and the removed rust particles with paper towels to make your bike brakes look as good as new!
Conclusione
After the user has completed these 4 simple steps, the exposed metal parts should be free of rust and ready to use. Repeat these steps for any other rusty metal parts of bicycle brakes.
Altre 9 persone hanno completato questa guida.
Eric Robinson
Membro da: 04/09/15
485 Reputazione
1 Guida realizzata
Cal Poly, Team 30-2, Green Spring 2015 Membro di Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Membri
4 Guide realizzate
1Commento della guida
the title says Lemon Juice, while all the references inside refer to Lime Juice.
richardwstevens - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,476
