Salta al contenuto principale
Holmes Blizzard Fan Oscillation Button Replacement
Mike Bolton
Mike Bolton e 3 altri collaboratori
Ultimo aggiornamento il August 27, 2021
20 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
In this guide, you will learn how to disassemble the majority of the Blizzard fan. By following these easy steps, you can clean, service, or replace several components of this fan.
  1. Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, immagine 1 di 3 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, immagine 2 di 3 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, immagine 3 di 3
    • Using a Phillips #2 Screwdriver, remove the 3 screws located on the back of the fan cage.
    • Next, loosen the screw located on the bottom of the fan.
    • The bottom screw does not need to be removed, but only loosened about 3 or 4 turns.
    • The front of the fan's cage is now able to be removed by prying the front away from the back.
  2. Holmes Blizzard Fan Oscillation Button Replacement: passo 2, immagine 1 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 2, immagine 2 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 2, immagine 3 di 3
    • Using a 7 mm socket and wrench, remove the 2 nuts that are behind the fan blades.
    • There is a washer located behind each nut. Be sure not to lose these.
  3. Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: passo 3, immagine 1 di 2 Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: passo 3, immagine 2 di 2
    • On the top of the fan, there is a screw fastening the oscillation button to the gear train within the housing. Remove this screw with the Phillips #0 Screwdriver.
  4. Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: passo 4, immagine 1 di 2 Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: passo 4, immagine 2 di 2
    • The on/off and fan speed nob can be removed by simply pulling it away from the main housing.
  5. Holmes Blizzard Fan Oscillation Button Replacement: passo 5, immagine 1 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 5, immagine 2 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 5, immagine 3 di 3
    • Remove the 2 screws holding the clear plastic plate in place with a Phillips #2 Screwdriver.
    • The plate is now free and can be taken out by hand.
  6. Holmes Blizzard Fan Oscillation Button Replacement: passo 6, immagine 1 di 2 Holmes Blizzard Fan Oscillation Button Replacement: passo 6, immagine 2 di 2
    • The motor switch is also free and can be removed by hand to reveal a screw holding the housing assembly in place.
    • Be sure not to damage the wires on the switch during removal. While you do not need to be overly gentle during this step, excessive force could cause the wires to be pulled out.
  7. Holmes Blizzard Fan Oscillation Button Replacement: passo 7, immagine 1 di 2 Holmes Blizzard Fan Oscillation Button Replacement: passo 7, immagine 2 di 2
    • Remove the screw that holds the housing assembly in place by using a Phillips #2 Screwdriver.
  8. Holmes Blizzard Fan Oscillation Button Replacement: passo 8, immagine 1 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 8, immagine 2 di 3 Holmes Blizzard Fan Oscillation Button Replacement: passo 8, immagine 3 di 3
    • The housing assembly can now be pulled off and pushed to the side to reveal the fan motor and gear train.
    • The oscillation button the was unscrewed earlier will fall out of the housing assembly.
    Then you put all back together you should make steps for that too hehe ?
    Rilee Watts - Replica
Conclusione
Altre 9 persone hanno completato questa guida.
Mike Bolton
Membro da: 07/17/16
570 Reputazione
2 Guide realizzate
4 Commenti
I wanted to let you know how pleasantly surprised I was to find your post when looking for instructions on the oscillation feature of my fan that is just like this one. Thank you for posting.
nancysmyowner - Replica
Thank you for this info. This made it so easy for me to take my fan apart and clean it.
Pamela Dacus - Replica
I used this guide to fix a Holmes Air HAOF-7, which is virtually identical. It was seizing and clicking while oscillating. Oiling the gear assembly fixed it right up. Thanks for posting!
Soft Serve - Replica
Thank you for this information, really helped me out a lot
Zane C. Waldon Sr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 59
Tutti i Tempi: 20,383
