Hasbro Furby 2012 Switch Replacement
Introduzione
Vai al passo 1This guide will show you how to replace the switch required for the back panel to be removed. The hardest part of this guide is removing the clips holding the fur on the back panel in place.
Cosa ti serve
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Locate and remove the two screws holding in the switch using J0 Phillips Head Screw Driver.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Orient the Furby with the beak facing right.
Using the blunt and pointed tweezers, remove the black connector.
Insert the new switch in place of where the previous connector was located.
Altre 2 persone hanno completato questa guida.
