Hand-Held Blender Motor Replacement
Introduzione
Vai al passo 1The fix is needed when the motor is worn out and overheats when used. To replace the old motor for a new one a Philips screwdriver (2mm), Tri-head screwdriver (2mm) and a soldering iron are needed. Also, you will need a new motor.
Cosa ti serve
