HTC One S Headphone Jack Replacement
Introduzione
Vai al passo 1This guide provides step-by-step instructions for replacing the headphone jack on the HTC One S. Intermediate soldering skills are required to remove the component.
Cosa ti serve
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Handling it by the tag, place the heated iOpener across the bottom casing.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using tweezers, remove the adhesive tape around the headphone jack.
