Salta al contenuto principale
HP ZBook 15 SSD Cache Replacement
Grant Terris
Grant Terris e 3 altri collaboratori
Ultimo aggiornamento il June 15, 2015
5 minuti
Facile
Introduzione
Vai al passo 1
Solid state drives are much faster than hard disk drives, but are much more expensive. The ZBook 15 comes with a small solid state storage unit called a cache. If you want your computer to run faster, you can move your operating system from the disk drive to the solid state cache. This will greatly decrease the amount of time it takes for your computer to boot from its powered-down or sleep states. If you need to replace the solid state cache on your laptop, follow this guide!
Cosa ti serve
Strumenti
  1. HP ZBook 15 SSD Cache Replacement, Battery: passo 1, immagine 1 di 2 HP ZBook 15 SSD Cache Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 SSD Cache Replacement, Back Cover: passo 2, immagine 1 di 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 SSD Cache Replacement, SSD Cache: passo 3, immagine 1 di 2 HP ZBook 15 SSD Cache Replacement, SSD Cache: passo 3, immagine 2 di 2
    • Remove the two 3 mm screws with a Phillips #0 screwdriver.
    • Remove the Solid State Cache by pulling the module up and out.
    Solid State Cache is mSATA, How max size mSATA SSD for HP ZBook15 G1?
    Gannon A - Replica
    I know I’m nearly three years late, but for anyone who’s wondering the same:
    The largest retail mSATA SSD I’ve seen is the Samsung 860 EVO mSATA 1TB. I have the 250GB version and it’s been great!
    If you’re willing to risk it, there is a guy (latency2050 ) selling 2TB mSATA drives for a bit less than $300 on ebay. Those are pulled from Samsung T3/T5 external SSDs, so you get exactly zero warranty.
    Luis Alejandro Araúz -
Conclusione
Altre 6 persone hanno completato questa guida.
Grant Terris
Membro da: 01/30/15
2.834 Reputazione
12 Guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
15 Guide realizzate
2Commenti sulla guida
Does it create a seprate volume drive by inserting the mSata SSD to install Operating System on it?
Reza Sajedi - Replica
Remember, this machine is from 2013, a time when SSDs were still hella expensive! That’s why the mSATA drive is refered to as a “cache” drive: they were so small they were only good for that. A stock, untouched Zbook g1/g2 might still come with a small (32GB) mSATA SSD configured as cache in the OS.
That doesn’t mean you can’t use the mSATA drive as your main OS drive, and that’s what I’ve been doing for years without a hint of trouble. You can easily find a high capacity mSATA SSD and put your OS and I/O-intensive programs on it. The Zbook will purr along nicely.
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 57
Tutti i Tempi: 12,401
