HP Stream 7 Screen Replacement
Introduzione
Vai al passo 1Since HP Stream 7 is a tablet and has many small parts. Be careful when removing/replacing parts. Do not force anything to avoid breaking device material.
Cosa ti serve
Make sure the tablet is powered off before beginning.
Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
Bonjour,
j'ai suivi la procédure pour remplacer la batterie, sans problème.
Cependant, la nouvelle batterie ne se recharge pas. J'ai changé de câble et de chargeur au cas où le problème viendrait de là mais sans succès. De plus, quand je branche la tablette sur le chargeur, elle indique bien être connectée au secteur mais sans charge de la batterie.
Quand je consulte le Bios, je vois que le numéro de série de batterie affiché est celui de l'ancienne batterie.
Y aurait-il une action à entreprendre à ce niveau ?
En vous remerciant par avance pour l'aide que vous pourriez m'apporter
Philippe
Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti6Commenti sulla guida
Same question but no answer !
Where can anyone find replacement screen online ??
We're I can buy the replacement screen?
