Salta al contenuto principale
HP Stream 7  Screen Replacement
Justin Schnorf
Justin Schnorf e 3 altri collaboratori
Ultimo aggiornamento il 9 ott 2018
7 minuti
Facile
Introduzione
Vai al passo 1
Since HP Stream 7 is a tablet and has many small parts. Be careful when removing/replacing parts. Do not force anything to avoid breaking device material.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Stream 7  Screen Replacement, Battery: passo 1, immagine 1 di 2 HP Stream 7  Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
  2. HP Stream 7  Screen Replacement: passo 2, immagine 1 di 2 HP Stream 7  Screen Replacement: passo 2, immagine 2 di 2
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
  3. HP Stream 7  Screen Replacement: passo 3, immagine 1 di 2 HP Stream 7  Screen Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
    Bonjour,
    j'ai suivi la procédure pour remplacer la batterie, sans problème.
    Cependant, la nouvelle batterie ne se recharge pas. J'ai changé de câble et de chargeur au cas où le problème viendrait de là mais sans succès. De plus, quand je branche la tablette sur le chargeur, elle indique bien être connectée au secteur mais sans charge de la batterie.
    Quand je consulte le Bios, je vois que le numéro de série de batterie affiché est celui de l'ancienne batterie.
    Y aurait-il une action à entreprendre à ce niveau ?
    En vous remerciant par avance pour l'aide que vous pourriez m'apporter
    Philippe
    Jacquemin Philippe - Replica
  4. HP Stream 7  Screen Replacement, Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
    • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
    • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
    • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
  5. HP Stream 7  Screen Replacement: passo 5, immagine 1 di 2 HP Stream 7  Screen Replacement: passo 5, immagine 2 di 2
    • Remove the two 2 mm Phillips 000 screws from the motherboard.
  6. HP Stream 7  Screen Replacement: passo 6, immagine 1 di 2 HP Stream 7  Screen Replacement: passo 6, immagine 2 di 2
    • Once unscrewed, the motherboard separates from the rest of the device.
    • The speaker is soldered to the motherboard, but it comes off easily.
    • Forced separation may result in a damaged motherboard and/or personal injury.
  7. HP Stream 7  Screen Replacement, Screen Replacement: passo 7, immagine 1 di 1
    • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
  8. HP Stream 7  Screen Replacement: passo 8, immagine 1 di 1
    • Using your spudger, pry the display panel off the front.
  9. HP Stream 7  Screen Replacement: passo 9, immagine 1 di 1
    • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
Conclusione
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team 18-5, Forte Fall 2016 Membro di Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Membri
6 Guide realizzate
6Commenti sulla guida
where can i buy new screen????
eibrims - Replica
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Replica
Where can i buy a new screen for the stream 7 please??
migueajr - Replica
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Replica
We're I can buy the replacement screen?
Raymond Borrero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,304
