Salta al contenuto principale
HP Pavilion 17-f004dx RAM Replacement
Allan Soria
Allan Soria e 4 altri collaboratori
Ultimo aggiornamento il December 18, 2016
20 - 45 minuti
Moderato
Introduzione
Vai al passo 1
This model's RAM is located in an unusual place, underneath the motherboard. The motherboard must first be carefully lifted before you can access the RAM.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Pavilion 17-f004dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx RAM Replacement: passo 2, immagine 1 di 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx RAM Replacement, CD Drive: passo 3, immagine 1 di 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion 17-f004dx RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion 17-f004dx RAM Replacement: passo 4, immagine 3 di 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx RAM Replacement, Front Panel: passo 5, immagine 1 di 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx RAM Replacement: passo 6, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 6, immagine 2 di 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx RAM Replacement: passo 7, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 7, immagine 2 di 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx RAM Replacement: passo 8, immagine 1 di 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx RAM Replacement: passo 9, immagine 1 di 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx RAM Replacement: passo 10, immagine 1 di 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx RAM Replacement: passo 11, immagine 1 di 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx RAM Replacement: passo 12, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 12, immagine 2 di 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx RAM Replacement: passo 13, immagine 1 di 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx RAM Replacement: passo 14, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 14, immagine 2 di 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx RAM Replacement: passo 15, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 15, immagine 2 di 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx RAM Replacement: passo 16, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 16, immagine 2 di 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx RAM Replacement, RAM: passo 17, immagine 1 di 1
    • Remove four 5.6 mm screws with a Phillips 1 screwdriver.
    • Remove one 3 mm screw with a Phillips 1 screwdriver.
  18. HP Pavilion 17-f004dx RAM Replacement: passo 18, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 18, immagine 2 di 2
    • Remove the ribbon connecting the optical drive bay to the motherboard.
  19. HP Pavilion 17-f004dx RAM Replacement: passo 19, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 19, immagine 2 di 2
    • Remove the ribbon connecting the hard drive to the motherboard.
  20. HP Pavilion 17-f004dx RAM Replacement: passo 20, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 20, immagine 2 di 2
    • Disconnect the ribbon from the motherboard that passes over the hard drive.
  21. HP Pavilion 17-f004dx RAM Replacement: passo 21, immagine 1 di 2 HP Pavilion 17-f004dx RAM Replacement: passo 21, immagine 2 di 2
    • There are still cables between the motherboard and the laptop.
    • Carefully lift the motherboard and lean it against the screen.
  22. HP Pavilion 17-f004dx RAM Replacement: passo 22, immagine 1 di 3 HP Pavilion 17-f004dx RAM Replacement: passo 22, immagine 2 di 3 HP Pavilion 17-f004dx RAM Replacement: passo 22, immagine 3 di 3
    • The motherboard has two slots for the RAM. The process for removing each one is the same
    • Pull the metal tabs away from the RAM.
  23. HP Pavilion 17-f004dx RAM Replacement: passo 23, immagine 1 di 1
    • Do not touch the circuits on the RAM. Only hold the RAM by its edges.
    • Gently remove the RAM from its slot.
Conclusione
Altre 3 persone hanno completato questa guida.
Allan Soria
Membro da: 09/21/16
638 Reputazione
4 Guide realizzate
UC Davis, Team 1-4, Oliver Fall 2016 Membro di UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,921
