Salta al contenuto principale
HP Pavilion 15-n210dx Hard Drive Replacement
Seth Shea
Seth Shea e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
25 - 30 minuti
Moderato
Necessarie Più Immagini
Necessarie Immagini Migliori
Dettagli Mancanti
Introduzione
Vai al passo 1
WARNING: The computer should be off (no power running), unplugged and the battery must be removed to prevent electrical shock.
If the hard drive needs to be replaced in the HP Pavilion 15-n210dx use this guide. The keyboard needs to be removed before opening up the laptop to get to the hard drive.
The hard drive, also known as hard drive disk (HDD) or solid state drive (SSD), is a hardware component of a computer that stores files and programs. If a lack of storage is causing hardware problems, make sure the new one has a larger storage capacity when you are replacing the old one. Other indications that the hard drive needs to be replaced, is the emitting of noises, crashes, or frequent error messages.
Back up the hard drive before starting the replacement to ensure files are safe. Once the new hard drive is installed, restore the files.
Tools that are needed is a Y0 screwdriver and a metal spudger.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP Pavilion 15-n210dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-n210dx Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-n210dx Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Hard Drive Replacement: passo 4, immagine 1 di 1
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-n210dx Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
  6. HP Pavilion 15-n210dx Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Use the Tri-point Y0 screwdriver to remove all screws on the metal sheet, then remove the metal sheet.
  7. HP Pavilion 15-n210dx Hard Drive Replacement: passo 7, immagine 1 di 2 HP Pavilion 15-n210dx Hard Drive Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the two blue wire connectors using the reverse tweezers and lift up on the two wires to disconnect them.
  8. HP Pavilion 15-n210dx Hard Drive Replacement: passo 8, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the twelve (12) screws from the back panel.
  9. HP Pavilion 15-n210dx Hard Drive Replacement: passo 9, immagine 1 di 2 HP Pavilion 15-n210dx Hard Drive Replacement: passo 9, immagine 2 di 2
    • Remove the optic drive by pushing the edge with your thumbs to open it. Once open use two hands to remove it entirely.
  10. HP Pavilion 15-n210dx Hard Drive Replacement: passo 10, immagine 1 di 1
    • Remove the screws that become exposed after removing the optic drive using a Phillips #0 screwdriver.
  11. HP Pavilion 15-n210dx Hard Drive Replacement: passo 11, immagine 1 di 2 HP Pavilion 15-n210dx Hard Drive Replacement: passo 11, immagine 2 di 2
    • Wedge the metal spudger between the black and silver plastic.
    • Slide the spudger along the edge of the laptop to help in ease of separation. Next use your hands to separate the black plastic from the silver plastic.
    • Avoid using the metal spudger unless it's for serious prying power. If used incorrectly, the metal spudger can damage the internal components of the device.
  12. HP Pavilion 15-n210dx Hard Drive Replacement: passo 12, immagine 1 di 3 HP Pavilion 15-n210dx Hard Drive Replacement: passo 12, immagine 2 di 3 HP Pavilion 15-n210dx Hard Drive Replacement: passo 12, immagine 3 di 3
    • Remove the two connectors that are attached to the hard drive by lifting up and away from the connected port.
  13. HP Pavilion 15-n210dx Hard Drive Replacement: passo 13, immagine 1 di 1
    • Remove the hard drive by lifting up on the back side of it.
Conclusione
Seth Shea
Membro da: 10/25/21
222 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,496
