Salta al contenuto principale
HP Pavilion 15-ay041wm LCD Screen Replacement
Rahmatullo Khudoi Nazar
Rahmatullo Khudoi Nazar e 3 altri collaboratori
Ultimo aggiornamento il July 28, 2020
10 minuti
Facile
Introduzione
Vai al passo 1
The LCD screen on laptops is one of the most important components as that is how the user can see and interact with the machine.
The screen might need to be replaced if it no longer produces a clear picture. If your laptop screen is cracked, dim, or producing vertical or horizontal lines, then your laptop might need a new LCD screen.
This 10-step guide will show you how to and replace the LCD screen in your HP Pavilion laptop with a Phillips #00 screwdriver.
Make sure the laptop is powered down before beginning this guide.
Cosa ti serve
Strumenti
  1. HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 2, immagine 2 di 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 3, immagine 3 di 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Place the laptop on a flat surface with the lid open.
  5. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 5, immagine 2 di 2
    • Gently pull away the bezel by the inner edge starting from the side until bezel is detached from screen.
    • To avoid scratching the screen, do not use any sharp objects.
  6. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 6, immagine 1 di 2 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 6, immagine 2 di 2
    • Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up.
  7. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the four 3mm screws that are holding the LCD panel in place.
  8. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 8, immagine 1 di 1
    • Gently pull the screen from the hooks and place it on the keyboard.
    • The video cable is attached to the bottom of the LCD screen.
  9. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 9, immagine 1 di 1
    • Peel the tape securing the video cable.
  10. HP Pavilion 15-ay041wm LCD Screen Replacement: passo 10, immagine 1 di 2 HP Pavilion 15-ay041wm LCD Screen Replacement: passo 10, immagine 2 di 2
    • Gently disconnect the video cable to detach the LCD screen from the back panel.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Hi. This is my first time trying to fix a computer by myself, but I'm desperate -old lady, low fixed income & this is my only computer. Please, please help! Trying to replace LCD cable, not the screen itself from HP15-ay041wm. [Screen fading from various shades of color to white & cursor freezes. Have to keep moving/tilting screen till find the “sweet spot". Then have to keep holding onto screen w/one hand while trying to type w/other. That lasts a few moments, but it eventually starts going goofy again & I have to find its new sweet spot. Hear this seems to be pretty common w/this model.] Followed your terrific directions & removed screen & disco’d the cable from screen, but now I'm stuck & panicking. How do I get the old cable past the hinge setup, get bad cable out of the main guts of the comp & get the new cable in? I've got this thing taken apart, scared to death I'm gonna ruin the whole computer and I can't afford a new one. So grateful for your help. Thx, God bless, be safe & well!
Bernadette - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,644
