Salta al contenuto principale
HP Pavilion 14-bk061st  Fan Replacement
Stefano Lo Re
Stefano Lo Re e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
2 - 4 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the fan in your HP Pavilion 14-bk061st laptop.
The computer fan as a core component that is used for active cooling inside a computer. It is important because it prevents a computer from overheating, as well as maintains better performance of computer parts by keeping them cool.
Before using this guide, confirm that the issue is that fan itself and not something else like dust buildup. This is a very common issue among computers that do not get cleaned out regularly. To find out more about this as well as other common fan issues visit the Troubleshooting page for more details.
Remember to power off the computer, as well as disconnecting all external components that are plugged into it.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Pavilion 14-bk061st  Fan Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 14-bk061st  Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st  Fan Replacement: passo 2, immagine 1 di 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st  Fan Replacement: passo 3, immagine 1 di 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st  Fan Replacement, Heat Sink: passo 4, immagine 1 di 2 HP Pavilion 14-bk061st  Fan Replacement, Heat Sink: passo 4, immagine 2 di 2
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  5. HP Pavilion 14-bk061st  Fan Replacement: passo 5, immagine 1 di 1
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  6. HP Pavilion 14-bk061st  Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  7. HP Pavilion 14-bk061st  Fan Replacement: passo 7, immagine 1 di 2 HP Pavilion 14-bk061st  Fan Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 738
