HP LaserJet 1160 or 1320 Formatter Replacement
Introduzione
Vai al passo 1Replace the formatter in an HP LaserJet 1160 or 1320.
Cosa ti serve
Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
Remove 2 screws on the I/O port cover.
Remove 6 screws on the formatter.
Disconnect 3 connectors from the formatter.
Disconnect 2 flat flexible cables from the formatter.
Remove the formatter from the printer.
Altre 2 persone hanno completato questa guida.
1Commento della guida
Additional connector attached to bottom left of board ignored
