Salta al contenuto principale
HP Elitebook Folio 9470m Hard Drive Replacement
Kenneth Bowers
Kenneth Bowers e 8 altri collaboratori
Ultimo aggiornamento il January 3, 2024
25 minuti
Moderato
Introduzione
Vai al passo 1
This guide will teach you how to replace a full or faulty hard drive on your HP Elitebook Folio 9470m.
The hard drive is the storage of your device; a faulty hard drive could cause crashes, long load times, excessive noise, and even loss of files.
Hard drives are very sensitive to sudden impacts, any impact could cause scratches on the disk inside the hard drive causing data loss.
Be sure if you have any important files on the hard drive to back them up before beginning the replacement. Make sure that the device is off and disconnected from any external power source before beginning.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Hard Drive Replacement: passo 2, immagine 1 di 2 HP Elitebook Folio 9470m Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove battery using This guide.
  3. HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, immagine 1 di 3 HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, immagine 2 di 3 HP Elitebook Folio 9470m Hard Drive Replacement: passo 3, immagine 3 di 3
    • Unscrew the 2 Phillips screws.
    • Slide the cover to the left, then remove the cover.
  4. HP Elitebook Folio 9470m Hard Drive Replacement: passo 4, immagine 1 di 1
    • Unscrew the 4 Phillips screws securing the hard drive.
  5. HP Elitebook Folio 9470m Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove by gently pulling up on the tab and out.
Conclusione
Altre 5 persone hanno completato questa guida.
Kenneth Bowers
Membro da: 04/08/16
1.432 Reputazione
7 Guide realizzate
2 Commenti
Pls I have lost my battery can u help me get another one for my lap please
Hw much will it cost
kingsleysenuduku - Replica
A bit late to the Party but you can find the battery on the main-site of the HP Elitebook Folio 9470m under the section «Parts»
RudiDerHirsch -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 66
Tutti i Tempi: 9,584
