Salta al contenuto principale
HP Elitebook 8460p Optical Drive Replacement
Garrett Anderson
Garrett Anderson e 2 altri collaboratori
Ultimo aggiornamento il December 6, 2019
7 - 10 minuti
Facile
Introduzione
Vai al passo 1
When the optical drive goes bad, the only way to fix the problem usually is to replace it. However, before completely replacing the optical drive in the HP Elitebook 8460p, attempt to clean the optical drive with a special cleaning disk.
If the cleaning disk does not solve the problem with the optical drive, use this guide to quickly and easily change the optical drive so you can go back to listening to music and watching movies.
The hardest part of the guide is removing a plastic component and putting it on the new optical drive. Take your time and remove the plastic piece carefully to avoid breaking it. Additionally, before opening up the bottom panel to the laptop, make sure you are properly grounded with an ESD grounding strap to prevent electrostatic discharges from damaging other electrical components of the laptop.
To complete this guide, you will need a Phillips #0 screw driver, a T2 Torx screw driver, an ESD strap, and a thin pry tool.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - Replica
  2. HP Elitebook 8460p Optical Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 3 di 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: passo 6, immagine 1 di 2 HP Elitebook 8460p Optical Drive Replacement: passo 6, immagine 2 di 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 3 di 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 3 di 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
Thanks for your help sir and I am really grateful
Mubarak Abubakar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,171
