Salta al contenuto principale
HP EliteBook x360 830 G7 Touchpad Removal
Alec Aviles
Alec Aviles e un altro collaboratore
Ultimo aggiornamento il June 25, 2024
20 - 40 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
This set of instructions will show how to properly replace the touchpad from your HP EliteBook x360 830 G7 laptop. This is used when the touchpad is no longer functional or there is a dent or scratch on the touchpad.
Before you begin this repair, turn off your laptop and unplug it from the charger.
Cosa ti serve
Ricambi
Strumenti
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • JIS #1
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: passo 1, immagine 1 di 3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: passo 1, immagine 2 di 3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the backplate: passo 1, immagine 3 di 3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Touchpad Removal, Disconnect the bundled cable connector: passo 2, immagine 1 di 1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: passo 3, immagine 1 di 2 HP EliteBook x360 830 G7 Touchpad Removal, Peel the copper foil tape: passo 3, immagine 2 di 2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: passo 4, immagine 1 di 2 HP EliteBook x360 830 G7 Touchpad Removal, Remove the screws: passo 4, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: passo 5, immagine 1 di 3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: passo 5, immagine 2 di 3 HP EliteBook x360 830 G7 Touchpad Removal, Remove the battery: passo 5, immagine 3 di 3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: passo 6, immagine 1 di 2 HP EliteBook x360 830 G7 Touchpad Removal, Touchpad: passo 6, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the six 2 mm screws holding the touchpad in place.
  7. HP EliteBook x360 830 G7 Touchpad Removal: passo 7, immagine 1 di 2 HP EliteBook x360 830 G7 Touchpad Removal: passo 7, immagine 2 di 2
    • Use a spudger or a clean fingernail to flip up the locking flap on the motherboard.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the tab.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  8. HP EliteBook x360 830 G7 Touchpad Removal: passo 8, immagine 1 di 2 HP EliteBook x360 830 G7 Touchpad Removal: passo 8, immagine 2 di 2
    • Use an opening tool or spudger to lift the metal bracket with the touchpad off of the laptop.
    • Remove the old touchpad.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alec Aviles
Membro da: 02/08/24
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 149
