Salta al contenuto principale
HP EliteBook x360 830 G7  Solid State Drive Replacement
Emily Kaplan
Emily Kaplan e 4 altri collaboratori
Ultimo aggiornamento il May 18, 2023
5 minuti
Facile
Introduzione
Vai al passo 1
This guide will help you replace the solid state drive from your HP EliteBook x360 830 G7 laptop.
The SSD is a piece of hardware that stores the digital content and data on your computer. The signs of a failing disk drive include overheating, unusual noises, program crashes, and/or a blue screen error.
Before using this guide, be sure to check out the troubleshooting page- sometimes malware and viruses can be removed without replacing the SSD.
NOTE: Make sure to back up your SSD in order to ensure that you do not lose any data.
Power off and disconnect the laptop from any power source before starting.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, immagine 1 di 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, immagine 2 di 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: passo 2, immagine 1 di 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 1 di 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 2 di 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: passo 4, immagine 1 di 1
    • Gently pull the SSD free from the M.2 socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 79
Tutti i Tempi: 1,557
