Salta al contenuto principale
HP EliteBook 850 G3 WiFi Card Replacement
Annabeth Grover
Annabeth Grover e 3 altri collaboratori
Ultimo aggiornamento il January 8, 2024
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
If your HP EliteBook 850 G3 laptop not connecting to the internet, use this guide to replace the wifi card in your device. Wireless Internet cards, also known as Local Area Network, or LAN, cards, are one of the many types of adapter cards that add capabilities to your computer. If the wifi card is faulty your laptop will not connect with the internet. Before beginning, make sure to power off your laptop completely and disconnect from any external power source. Before using this guide, feel free to check out the troubleshooting page to see if any issues can be resolved without a replacement.
Cosa ti serve
Strumenti
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: passo 1, immagine 1 di 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: passo 2, immagine 1 di 2 HP EliteBook 850 G3 WiFi Card Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: passo 3, immagine 1 di 2 HP EliteBook 850 G3 WiFi Card Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: passo 5, immagine 1 di 2 HP EliteBook 850 G3 WiFi Card Replacement: passo 5, immagine 2 di 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: passo 6, immagine 1 di 3 HP EliteBook 850 G3 WiFi Card Replacement: passo 6, immagine 2 di 3 HP EliteBook 850 G3 WiFi Card Replacement: passo 6, immagine 3 di 3
    • Disconnect the coaxial cables wires from the WiFi card.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro di USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Membri
6 Guide realizzate
Un commento
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,811
