Salta al contenuto principale
HP EliteBook 820 G3 Keyboard Replacement
Caleb Morales
Caleb Morales e 2 altri collaboratori
Ultimo aggiornamento il December 27, 2022
15 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to replace the keyboard for the HP EliteBook 820 G3 laptop. If any of the keys do not work or the small track pad on the keyboard does not work, the keyboard will need to be replaced. Before beginning, power off the device and disconnect any external power supply.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP EliteBook 820 G3 Keyboard Replacement, Back Cover: passo 1, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Keyboard Replacement: passo 2, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 1 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 2 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use an iFixit opening pick to gently pry open the top of the keyboard.
    • Gently pull the keyboard up until you can see the three ribbons under the keyboard.
  5. HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 1 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 2 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 3 di 3
    • Lift up the latch holding down the ribbon and pull the ribbon out once it is lifted.
    • Repeat for all three of the ribbons.
    • The white ribbon (left ribbon) sometimes does not come with a new keyboard. You may need to detach it and add it to the replacement if necessary.
Conclusione
Altre 4 persone hanno completato questa guida.
Caleb Morales
Membro da: 08/25/22
184 Reputazione
1 Guida realizzata
Gateway, Team 1-1, Class Fall 2022 Membro di Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 Membri
6 Guide realizzate
1Commento della guida
I did this, it won’t stay in.
Serial Action - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,747
