Salta al contenuto principale
HP 15-da0002dx SSD Replacement
Abigail Aron
Abigail Aron e 2 altri collaboratori
Ultimo aggiornamento il 16 nov 2022
10 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
If your HP Notebook 15-da0002dx laptop is making ticking sounds, experiences frequent crashes, or if your computer has trouble reading files, saving files, or is generally running slow, the SSD may need to be replaced. The SSD (Solid State Drive) acts as a storage device that reads, writes, and stores data.
Before using this guide, make sure your computer’s issues are not caused by its software. Restart the computer and see of the problems continue. If not, make sure your computer’s operating system is updated.
Before using this guide, power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP 15-da0002dx SSD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the computer is completely turned off.
    Your instructions worked perfectly. My machine had a 1 TB sata drive 5400 rpm and I replaced it with a Kingston ssd and cloned it prior to installing. Works perfectly.
    The rubber feet on the computer cracked but was able to stick them back on. May need to be glued if they come off. Thank You, Irwin
    Irwin - Replica
  2. HP 15-da0002dx SSD Replacement: passo 2, immagine 1 di 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx SSD Replacement: passo 3, immagine 1 di 2 HP 15-da0002dx SSD Replacement: passo 3, immagine 2 di 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
    thanks for posting this writeup. something to take not of, is the rubber strippings (feet) are of two different sizes
    - the thicker rubber strip goes on the back side
    - the thinner rubber strip goes on/towards the front
    chrisrjones1983 - Replica
  4. HP 15-da0002dx SSD Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx SSD Replacement: passo 5, immagine 1 di 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
    need to Remove the CD rom drive prior to prying the two halves apart. If all the screws are removed from step 2 it should just slide out.
    ElectroDad - Replica
  6. HP 15-da0002dx SSD Replacement: passo 6, immagine 1 di 2 HP 15-da0002dx SSD Replacement: passo 6, immagine 2 di 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx SSD Replacement: passo 7, immagine 1 di 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx SSD Replacement, Battery: passo 8, immagine 1 di 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
    I put my m.2 but i didn't remove the battery before and when I opened my laptop the m.2 wasn't showed on (my computer)
    Ali Hamdi - Replica
  9. HP 15-da0002dx SSD Replacement: passo 9, immagine 1 di 2 HP 15-da0002dx SSD Replacement: passo 9, immagine 2 di 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx SSD Replacement, SSD: passo 10, immagine 1 di 1
    • Remove the screw holding the SSD in place using the Phillips #1 screwdriver.
    Is there a way to add a HDD by the DVD drive and battery (the empty spot that looks like it could fit a 2.5” SATA drive but needs soldering)?
    Lazùn Stargate - Replica
  11. HP 15-da0002dx SSD Replacement: passo 11, immagine 1 di 1
    • Carefully pull the SSD away from the socket.
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
sir
can we add a hdd of 1tb also without replacing ssd???
Kranti Ajit - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,250
