Google Pixel C Power Button Replacement
Introduzione
Vai al passo 1This guide will outline how to replace the power button should it be non responsive or faulty.
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Follow the same removal procedure to detach the wide gold cable.
This is not very useful if there is no way of getting the parts.
Hi i seem to have a loose item in my pixel c causing the backlight to not light up, when it doesn’t i can bang on the device and it will come on.
my question is if i am able to remove the screen in one piece what type of adhesive do i need to re-glue it also leaving it able to be re heated to be removed in the future if need be
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
