Salta al contenuto principale
Google Pixel 9 Pro XL Screen Replacement
Cosa ti serve
  1. Google Pixel 9 Pro XL Screen Replacement, Safety precautions: passo 1, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
  2. Google Pixel 9 Pro XL Screen Replacement, Tape over any cracks: passo 2, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Chiedi a FixBot
  3. Google Pixel 9 Pro XL Screen Replacement: passo 3, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 3, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 3, immagine 3 di 3
    • Adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
    Chiedi a FixBot
  4. Google Pixel 9 Pro XL Screen Replacement, Apply a suction handle: passo 4, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement, Apply a suction handle: passo 4, immagine 2 di 2
    • Apply a suction handle to the center of the screen's top edge.
    Chiedi a FixBot
  5. Google Pixel 9 Pro XL Screen Replacement, Screen information: passo 5, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Screen information: passo 5, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Screen information: passo 5, immagine 3 di 3
    • There are delicate metal spring‑contacts around the perimeter of your device. To prevent damaging them when separating the screen, don't insert your pick more than 3 mm deep.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
  6. Google Pixel 9 Pro XL Screen Replacement, Insert an opening pick: passo 6, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Insert an opening pick: passo 6, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Inserting an opening pick is difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • Insert the tip of an opening pick under the screen.
    • A plastic frame is attached to the backside of the display. When inserting your pick, make sure it's underneath this frame, and not between the frame and the display glass.
    Chiedi a FixBot
  7. Google Pixel 9 Pro XL Screen Replacement, Separate the screen adhesive: passo 7, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Separate the screen adhesive: passo 7, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Separate the screen adhesive: passo 7, immagine 3 di 3
    • Slide the opening pick along the top edge to separate the adhesive securing it.
    Chiedi a FixBot
  8. Google Pixel 9 Pro XL Screen Replacement: passo 8, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 8, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 8, immagine 3 di 3
    • Continue sliding your opening pick around the perimeter of the screen to separate the remaining adhesive.
    Chiedi a FixBot
  9. Google Pixel 9 Pro XL Screen Replacement, Prop up the screen: passo 9, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Prop up the screen: passo 9, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Prop up the screen: passo 9, immagine 3 di 3
    • Flip the screen over the right edge of your phone and prop it up with the suction handle.
    • Be careful not to strain the display cable, located near the bottom right corner.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    Chiedi a FixBot
  10. Google Pixel 9 Pro XL Screen Replacement, Disconnect the screen: passo 10, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Disconnect the screen: passo 10, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Disconnect the screen: passo 10, immagine 3 di 3
    • Use angled tweezers to pry up the top edge of the screen cable bracket.
    • Remove the bracket.
    Chiedi a FixBot
  11. Google Pixel 9 Pro XL Screen Replacement: passo 11, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 11, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 11, immagine 3 di 3
    • Be very careful not to damage any of the small, surface‑mounted components around the screen's press connector.
    • Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
    • Remove the screen.
    Chiedi a FixBot
  12. Google Pixel 9 Pro XL Screen Replacement, Screen information: passo 12, immagine 1 di 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Chiedi a FixBot
  13. Google Pixel 9 Pro XL Screen Replacement, Remove all the old screen adhesive: passo 13, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove all the old screen adhesive: passo 13, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove all the old screen adhesive: passo 13, immagine 3 di 3
    • When removing the screen adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
    • Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
    • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
    • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
    • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
    • Allow the frame to dry completely before continuing.
    Chiedi a FixBot
  14. Google Pixel 9 Pro XL Screen Replacement, Orient the adhesive: passo 14, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Orient the adhesive: passo 14, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Orient the adhesive: passo 14, immagine 3 di 3
    • If your replacement screen has adhesive pre‑installed, skip down seven steps. Otherwise, follow the next seven steps to install new screen adhesive.
    • Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
    • The blue liner should be facing up, with the larger clear liner on the bottom.
    • The adhesive has a corresponding groove on the perimeter of the frame.
    • Cutouts in the blue liner correspond to spring contacts on the frame.
    Chiedi a FixBot
  15. Google Pixel 9 Pro XL Screen Replacement, Apply the screen adhesive: passo 15, immagine 1 di 1
    • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
    Chiedi a FixBot
  16. Google Pixel 9 Pro XL Screen Replacement: passo 16, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement: passo 16, immagine 2 di 2
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger, clear liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the frame's lip to help align it.
    • Once the top edge is properly aligned, gently press down with your fingers to secure it in place.
    Chiedi a FixBot
  17. Google Pixel 9 Pro XL Screen Replacement: passo 17, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 17, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 17, immagine 3 di 3
    • Slowly lay the rest of the adhesive onto the frame, peeling away the larger clear liner as you go.
    Chiedi a FixBot
  18. Google Pixel 9 Pro XL Screen Replacement, Secure the screen adhesive: passo 18, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Secure the screen adhesive: passo 18, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Secure the screen adhesive: passo 18, immagine 3 di 3
    • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
    Chiedi a FixBot
  19. Google Pixel 9 Pro XL Screen Replacement: passo 19, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement: passo 19, immagine 2 di 2
    • Use tweezers to grip the top left corner of the blue liner and remove it.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
    Chiedi a FixBot
  20. Google Pixel 9 Pro XL Screen Replacement: passo 20, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 20, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 20, immagine 3 di 3
    Chiedi a FixBot
  21. Google Pixel 9 Pro XL Screen Replacement, Connect the replacement screen: passo 21, immagine 1 di 1
    • Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
    Chiedi a FixBot
  22. Google Pixel 9 Pro XL Screen Replacement: passo 22, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement: passo 22, immagine 2 di 2
    • Be very careful not to strain the screen cable during this step. You may need to hold the screen up at an angle to help position the cable.
    • Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
    • Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
    Chiedi a FixBot
  23. Google Pixel 9 Pro XL Screen Replacement, Remove any small liners: passo 23, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove any small liners: passo 23, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove any small liners: passo 23, immagine 3 di 3
    • Leave the perimeter display adhesive liners in place for now.
    • Thoroughly check your replacement screen for any small plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
    • Be very careful not to damage the screen when removing the liners.
    Chiedi a FixBot
  24. Google Pixel 9 Pro XL Screen Replacement, Remove the screen adhesive liner: passo 24, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove the screen adhesive liner: passo 24, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement, Remove the screen adhesive liner: passo 24, immagine 3 di 3
    • Follow this step only if your screen has adhesive pre‑installed on the underside.
    • Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
    • Skip the next step.
    Chiedi a FixBot
  25. Google Pixel 9 Pro XL Screen Replacement: passo 25, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 25, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 25, immagine 3 di 3
    • Follow this step if you applied screen adhesive directly to the frame.
    • Use tweezers or your fingers to remove the two remaining liners from the frame. You'll need to carefully hold the screen up to remove the right liner.
    Chiedi a FixBot
  26. Google Pixel 9 Pro XL Screen Replacement, Secure the screen with its adhesive: passo 26, immagine 1 di 2 Google Pixel 9 Pro XL Screen Replacement, Secure the screen with its adhesive: passo 26, immagine 2 di 2
    • Carefully flip the screen onto the frame.
    Chiedi a FixBot
  27. Google Pixel 9 Pro XL Screen Replacement: passo 27, immagine 1 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 27, immagine 2 di 3 Google Pixel 9 Pro XL Screen Replacement: passo 27, immagine 3 di 3
    • Firmly press around the perimeter of the screen to secure it to the frame.
    • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
    Chiedi a FixBot
Conclusione
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
Altre 20 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
187.948 Reputazione
1.187 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.707 guide realizzate
7Commenti sulla guida
do we need to do calibrate the screen or UDFPS PUnder Display FingerPrint Sensor) for this google pixel 9 pro xl after the screen replacement ?
David Kang - Rispondi Condividi
Hi David! You don't need to calibrate the UDFPS for the Pixel 9 series phones. When powering the phone on for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen. I've added a note about this is the guides. Thank you!
Spencer Day - Rispondi Condividi
Thanks for the guide replaced my brother's screen with the one I bought from you guys!
Matthew Iam - Rispondi Condividi
the quide was clear and helpful but there is one contredidction with it at step 22 it said to test ther device. but later at the end it says during first boot not to touch the device.
beside that the guide and tools provided are amazing
Jay Bulté - Rispondi Condividi
That's a great point! Thanks for the comment, we've updated the guide accordingly.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 50
Ultimi 7 Giorni: 255
Ultimi 30 Giorni: 1,095
Tutti i Tempi: 17,375
