Salta al contenuto principale
Google Pixel 9 Front Camera Replacement
Cosa ti serve
  1. Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: passo 1, immagine 3 di 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9 Front Camera Replacement, Adhesive information: passo 2, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Adhesive information: passo 2, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Adhesive information: passo 2, immagine 3 di 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9 Front Camera Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9 Front Camera Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: passo 5, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: passo 5, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: passo 5, immagine 3 di 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9 Front Camera Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Front Camera Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Front Camera Replacement: passo 6, immagine 3 di 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9 Front Camera Replacement: passo 7, immagine 1 di 3 Google Pixel 9 Front Camera Replacement: passo 7, immagine 2 di 3 Google Pixel 9 Front Camera Replacement: passo 7, immagine 3 di 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9 Front Camera Replacement, Remove the back glass: passo 8, immagine 1 di 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9 Front Camera Replacement, Remove the upper board cover: passo 9, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9 Front Camera Replacement: passo 10, immagine 1 di 2 Google Pixel 9 Front Camera Replacement: passo 10, immagine 2 di 2
    • Use a pair of tweezers to remove the upper board cover.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9 Front Camera Replacement, Remove the midframe: passo 11, immagine 1 di 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9 Front Camera Replacement, Peel up the flash cable: passo 12, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Peel up the flash cable: passo 12, immagine 2 di 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 9 Front Camera Replacement, Remove the midframe: passo 13, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Remove the midframe: passo 13, immagine 2 di 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 9 Front Camera Replacement, Disconnect the battery: passo 14, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Disconnect the battery: passo 14, immagine 2 di 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 9 Front Camera Replacement, Disconnect the front camera: passo 15, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Disconnect the front camera: passo 15, immagine 2 di 2
    • Use the tip of a spudger to pry up and disconnect the front camera's press connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: passo 16, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: passo 16, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: passo 16, immagine 3 di 3
    • Insert the flat end of a spudger between the top edge of the front camera and the frame.
    • Pivot the spudger down, against the frame to pry the front camera up and out of its recess.
    • Remove the front camera.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: passo 17, immagine 1 di 3 Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: passo 17, immagine 2 di 3 Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: passo 17, immagine 3 di 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining liner from the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 9 Front Camera Replacement, Adhere the front facing camera: passo 18, immagine 1 di 2 Google Pixel 9 Front Camera Replacement, Adhere the front facing camera: passo 18, immagine 2 di 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable facing the right edge, press the front facing camera into its recess to secure it with the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
Membro da: 03/10/20
165.651 Reputazione
439 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 17
Ultimi 30 giorni: 94
Tutti i Tempi: 1,766
