G603 Wheel Encoder Replacement
Introduzione
Vai al passo 1Logitech G603 mouse wheel encoder replacement.
The encoder is a Logitech 210-001795. It's possible the PCB color on replacements is different than what's inside the G603.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
Use Phillips #00 to remove the four bottom screws
Start at the top above the left and right click and slowly work your way around the shells until they are separated
Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
Start with the red and black power cable and gently pull it out
Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
Gently pull out the black ribbon cable connecting the encoder board to the main board
Remove the Phillips #00 screws holding the encoder board in place
Remove the encoder board from the bottom shell
Gently remove the wheel from the older encoder board
NOTE: The old wheel can be reused in the replacement encoder board
