Salta al contenuto principale
Fujitsu Siemens Amilo Pro Keyboard Replacement
Jeremy Scalpello
Jeremy Scalpello e 3 altri collaboratori
Ultimo aggiornamento il February 16, 2020
Nessuna stima
Moderato
Foto Azione
Necessarie Immagini Migliori
Inconveniente Markup
Guida fornita dalla comunità
Introduzione
Vai al passo 1
A repair manual for the Fujitsu Siemens Amilo Pro 2010 and 2020 and 2030 which shows you how to replace the keyboard!
Cosa ti serve
Strumenti
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 2, immagine 1 di 1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 4, immagine 1 di 1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 5, immagine 1 di 1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Conclusione
Un commento
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 15,766
