Salta al contenuto principale
Fujitsu Siemens Amilo Pro Keyboard Replacement
Cosa ti serve
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 2, immagine 1 di 1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 4, immagine 1 di 1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: passo 5, immagine 1 di 1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Conclusione
Un commento
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 15,769
