Salta al contenuto principale
Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement
Spencer Bacon
Spencer Bacon e 4 altri collaboratori
Ultimo aggiornamento il February 19, 2020
4 minuti
Moderato
Introduzione
Vai al passo 1
This is another protective layer you will need to remove prior to accessing the internal parts of the device.
Cosa ti serve
Strumenti
Mostra di più…
  1. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: passo 3, immagine 1 di 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Inner Back Shield: passo 4, immagine 1 di 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: passo 5, immagine 1 di 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: passo 6, immagine 1 di 1
  7. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: passo 7, immagine 1 di 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 527
