Salta al contenuto principale
Edifier W820NB Plus Drivers Replacement
Cosa ti serve
    1. Edifier W820NB Plus Drivers Replacement, Ear Pads: passo 1, immagine 1 di 1
      • Start with the headphones face up and the earpads visible.
      Chiedi a FixBot
      Aggiungi Commento
    2. Edifier W820NB Plus Drivers Replacement: passo 2, immagine 1 di 2 Edifier W820NB Plus Drivers Replacement: passo 2, immagine 2 di 2
      • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Edifier W820NB Plus Drivers Replacement: passo 3, immagine 1 di 2 Edifier W820NB Plus Drivers Replacement: passo 3, immagine 2 di 2
      • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
      • Repeat this procedure for the other side if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    4. Edifier W820NB Plus Drivers Replacement: passo 4, immagine 1 di 1
      • Repeat for the other side if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    1. Edifier W820NB Plus Drivers Replacement, Drivers: passo 5, immagine 1 di 1
      • Identify the driver you wish to replace.
      • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Edifier W820NB Plus Drivers Replacement: passo 6, immagine 1 di 2 Edifier W820NB Plus Drivers Replacement: passo 6, immagine 2 di 2
      • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
      Chiedi a FixBot
      Aggiungi Commento
    3. Edifier W820NB Plus Drivers Replacement: passo 7, immagine 1 di 3 Edifier W820NB Plus Drivers Replacement: passo 7, immagine 2 di 3 Edifier W820NB Plus Drivers Replacement: passo 7, immagine 3 di 3
      • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
      • Insert a Jimmy in the seam between the driver assembly and driver housing.
      • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Edifier W820NB Plus Drivers Replacement: passo 8, immagine 1 di 2 Edifier W820NB Plus Drivers Replacement: passo 8, immagine 2 di 2
      • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
      Chiedi a FixBot
      Aggiungi Commento
    5. Edifier W820NB Plus Drivers Replacement: passo 9, immagine 1 di 2 Edifier W820NB Plus Drivers Replacement: passo 9, immagine 2 di 2
      • Skip this step if you are completing a battery replacement.
      • Repeat the procedure for the other driver if necessary.
      • Desolder the four driver connections from the motherboard.
      • Remove the driver assembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Happy Zhang
Membro da: 03/21/25
438 Reputazione
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 18
Ultimi 30 giorni: 46
Tutti i Tempi: 647
