Salta al contenuto principale
DualShock 3 Front Shell Cover Replacement
Joseph Wambui
Joseph Wambui e un altro collaboratore
Ultimo aggiornamento il October 19, 2024
30 - 45 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace a worn out, broken or damaged shell of a DualShock 3 controller.
The DualShock 3 weighs about 192 grams and the product dimensions are 15.98 X 5.99 X 9.98 cm. It has a connection port USB mini B but also utilizes Bluetooth technology wireless connection for seamless gameplay.
The following procedure will require disassembling the controller and assembling it back after replacing the damaged front shell which may be caused by breaking when dropped one too many times on the ground or from dislodged joy sticks due to friction. This may lead to damage of the interior of the controller such as the motherboard, battery or motors for example.
Before beginning make sure to disconnect from any external power source like the console.
Cosa ti serve
Strumenti
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: passo 1, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: passo 1, immagine 2 di 2
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
  2. DualShock 3 Front Shell Cover Replacement: passo 2, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 2, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
  3. DualShock 3 Front Shell Cover Replacement: passo 3, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement: passo 3, immagine 2 di 2
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
  4. DualShock 3 Front Shell Cover Replacement: passo 4, immagine 1 di 1
    • Lift the rear cover off of the controller to expose the interior.
  5. DualShock 3 Front Shell Cover Replacement: passo 5, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 5, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 5, immagine 3 di 3
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
  6. DualShock 3 Front Shell Cover Replacement: passo 6, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 6, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 6, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
  7. DualShock 3 Front Shell Cover Replacement: passo 7, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement: passo 7, immagine 2 di 2
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
    What do you mean by “be careful not to strip the plastic rubber” which is where?
    Daquan - Replica
  8. DualShock 3 Front Shell Cover Replacement: passo 8, immagine 1 di 1
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
Conclusione
Altre 4 persone hanno completato questa guida.
Joseph Wambui
Membro da: 07/09/21
253 Reputazione
1 Guida realizzata
2Commenti sulla guida
Personally I believe with the current price of a DualShock 3 controller its not even worth it to replace the following parts. Or maybe its just me? Sony has done a great product and will continue to do so!
Andrew McMason - Replica
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 125
Tutti i Tempi: 4,990
