Salta al contenuto principale
Disconnecting Microphone from Motherboard
Timothy Forrest
Timothy Forrest e 5 altri collaboratori
Ultimo aggiornamento il December 26, 2022
Nessuna stima
Difficile
Introduzione Migliore
Cosa ti serve
Strumenti
  1. Disconnecting Microphone from Motherboard, Front and Back Cover: passo 1, immagine 1 di 2 Disconnecting Microphone from Motherboard, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Motherboard: passo 2, immagine 1 di 2 Disconnecting Microphone from Motherboard: passo 2, immagine 2 di 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Motherboard, Microphone Connection: passo 3, immagine 1 di 2 Disconnecting Microphone from Motherboard, Microphone Connection: passo 3, immagine 2 di 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
Conclusione
Cal Poly, Team 12-34, Amido Spring 2013 Membro di Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membri
16 Guide realizzate
Un commento
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,802
