Salta al contenuto principale
Disassembling VTech MobiGo Touch Learning System Keyboard
RBansil
RBansil e 5 altri collaboratori
Ultimo aggiornamento il 10 mag 2020
20 minuti
Moderato
Introduzione
Vai al passo 1
This is a step by step guide to show how to replace the keyboard. Prior to this guide, you will need to refer to the Disassembling guide for the case.
Cosa ti serve
Strumenti
Mostra di più…
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: passo 1, immagine 1 di 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, immagine 2 di 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, immagine 2 di 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, immagine 2 di 2
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 5, immagine 1 di 1
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, immagine 2 di 2
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 1 di 3 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 2 di 3 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 3 di 3
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 8, immagine 1 di 1
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, immagine 2 di 2
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 10, immagine 1 di 1
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 11, immagine 1 di 1
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 12, immagine 1 di 1
    • Gently remove the keyboard circuit board with a plastic opening tool.
    Where do you get a replacement circuit board?
    Kara - Replica
Conclusione
Preparati per le riparazioni future
Acquista tutti
RBansil
Membro da: 08/27/15
221 Reputazione
2 Guide realizzate
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 Guide realizzate
1Commento della guida
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,083
