Salta al contenuto principale
Disassembling Samsung NX3000
Kelsea Weber
Kelsea Weber e un altro collaboratore
Ultimo aggiornamento il May 7, 2024
Nessuna stima
Moderato
Introduzione
Vai al passo 1
This guide gives you a look at the major components of the Samsung NX3000 and provides complete disassembly instructions.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Cosa ti serve
Strumenti
Mostra di più…
  1. Disassembling Samsung NX3000, Battery: passo 1, immagine 1 di 3 Disassembling Samsung NX3000, Battery: passo 1, immagine 2 di 3 Disassembling Samsung NX3000, Battery: passo 1, immagine 3 di 3
    • Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
    • Slide the button to the left to open the battery compartment.
    • Push the blue button up to release the battery.
    • The battery is not shown in these photos.
  2. Disassembling Samsung NX3000, Disassembling Samsung NX3000: passo 2, immagine 1 di 2 Disassembling Samsung NX3000, Disassembling Samsung NX3000: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
    • Remove the silver ring with tweezers.
  3. Disassembling Samsung NX3000: passo 3, immagine 1 di 2 Disassembling Samsung NX3000: passo 3, immagine 2 di 2
    • Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
  4. Disassembling Samsung NX3000: passo 4, immagine 1 di 3 Disassembling Samsung NX3000: passo 4, immagine 2 di 3 Disassembling Samsung NX3000: passo 4, immagine 3 di 3
    • Use tweezers to remove the pin and small spring from the lens assembly.
  5. Disassembling Samsung NX3000: passo 5, immagine 1 di 2 Disassembling Samsung NX3000: passo 5, immagine 2 di 2
    • Remove the three 4.3 mm Phillips screws from the bottom of the camera.
    • Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
  6. Disassembling Samsung NX3000: passo 6, immagine 1 di 2 Disassembling Samsung NX3000: passo 6, immagine 2 di 2
    • Remove the 4.2 mm Phillips screw from the left handgrip.
    • Remove the two 4.2 mm Phillips screws from the right handgrip.
  7. Disassembling Samsung NX3000: passo 7, immagine 1 di 2 Disassembling Samsung NX3000: passo 7, immagine 2 di 2
    • Use tweezers to pull the metal shield straight out of the external flash mount.
  8. Disassembling Samsung NX3000: passo 8, immagine 1 di 1
    • Remove the four 5 mm Phillips screws from the external flash mount .
  9. Disassembling Samsung NX3000: passo 9, immagine 1 di 2 Disassembling Samsung NX3000: passo 9, immagine 2 di 2
    • Remove the external flash mount.
  10. Disassembling Samsung NX3000: passo 10, immagine 1 di 2 Disassembling Samsung NX3000: passo 10, immagine 2 di 2
    • Slowly pull the bottom of the back case away from the camera.
    • Do not attempt to remove the back case as it is attached to the motherboard by a ribbon cable.
  11. Disassembling Samsung NX3000: passo 11, immagine 1 di 3 Disassembling Samsung NX3000: passo 11, immagine 2 di 3 Disassembling Samsung NX3000: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to pry the flat topped connector straight up from the motherboard.
    • Remove the back case.
  12. Disassembling Samsung NX3000: passo 12, immagine 1 di 3 Disassembling Samsung NX3000: passo 12, immagine 2 di 3 Disassembling Samsung NX3000: passo 12, immagine 3 di 3
    • Use the pointed end of a spudger to lift the ribbon cable straight out of the black clip located near the left handgrip.
  13. Disassembling Samsung NX3000: passo 13, immagine 1 di 2 Disassembling Samsung NX3000: passo 13, immagine 2 di 2
    • Use tweezers to pull the tripod mount out of the front case.
  14. Disassembling Samsung NX3000: passo 14, immagine 1 di 3 Disassembling Samsung NX3000: passo 14, immagine 2 di 3 Disassembling Samsung NX3000: passo 14, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the large ribbon cable by prying its metal connector straight up from the motherboard.
  15. Disassembling Samsung NX3000: passo 15, immagine 1 di 3 Disassembling Samsung NX3000: passo 15, immagine 2 di 3 Disassembling Samsung NX3000: passo 15, immagine 3 di 3
    • Use the pointed tip of a spudger to unlock the ZIF connector by flipping the black bar straight up from the motherboard.
  16. Disassembling Samsung NX3000: passo 16, immagine 1 di 2 Disassembling Samsung NX3000: passo 16, immagine 2 di 2
    • Insert the pointed end of a spudger into the hole on the ribbon cable.
    • Pull the ribbon cable straight out of the ZIF connector.
  17. Disassembling Samsung NX3000: passo 17, immagine 1 di 3 Disassembling Samsung NX3000: passo 17, immagine 2 di 3 Disassembling Samsung NX3000: passo 17, immagine 3 di 3
    • Insert the pointed end of a spudger into the hole on the ribbon cable in the bottom left corner of the motherboard.
    • Pull the ribbon straight out of the connector.
  18. Disassembling Samsung NX3000: passo 18, immagine 1 di 3 Disassembling Samsung NX3000: passo 18, immagine 2 di 3 Disassembling Samsung NX3000: passo 18, immagine 3 di 3
    • Use tweezers to remove the green tape covering the ribbon cable on the image sensor.
  19. Disassembling Samsung NX3000: passo 19, immagine 1 di 2 Disassembling Samsung NX3000: passo 19, immagine 2 di 2
    • Use the pointed tip of a spudger to flip the black bar on the ZIF connector straight up from the ribbon cable.
  20. Disassembling Samsung NX3000: passo 20, immagine 1 di 2 Disassembling Samsung NX3000: passo 20, immagine 2 di 2
    • Pull the ribbon cable straight out of the connector.
  21. Disassembling Samsung NX3000: passo 21, immagine 1 di 1
    • Use a spudger to peel back the large ribbon cable on the sensor assembly.
    • The ribbon cable may be attached with adhesive.
  22. Disassembling Samsung NX3000: passo 22, immagine 1 di 1
    • Remove the two black 3.8 mm Phillips screws on the sensor assembly.
  23. Disassembling Samsung NX3000: passo 23, immagine 1 di 1
    • Remove the three 5.3 mm Phillips screws holding the sensor assembly in place.
  24. Disassembling Samsung NX3000: passo 24, immagine 1 di 1
    • Remove the image sensor.
  25. Disassembling Samsung NX3000: passo 25, immagine 1 di 3 Disassembling Samsung NX3000: passo 25, immagine 2 di 3 Disassembling Samsung NX3000: passo 25, immagine 3 di 3
    • Remove the three 4.3 mm Phillips screws from the motherboard.
    • Remove the motherboard from the camera.
  26. Disassembling Samsung NX3000: passo 26, immagine 1 di 3 Disassembling Samsung NX3000: passo 26, immagine 2 di 3 Disassembling Samsung NX3000: passo 26, immagine 3 di 3
    • Remove the two 5.3 mm Phillips screws holding the sensor frame to the case.
    • Remove the sensor frame.
  27. Disassembling Samsung NX3000: passo 27, immagine 1 di 2 Disassembling Samsung NX3000: passo 27, immagine 2 di 2
    • Remove the 4.3 mm Phillips screw in the upper left corner that secures the top plate to the front case
  28. Disassembling Samsung NX3000: passo 28, immagine 1 di 2 Disassembling Samsung NX3000: passo 28, immagine 2 di 2
    • Remove the top plate.
  29. Disassembling Samsung NX3000: passo 29, immagine 1 di 3 Disassembling Samsung NX3000: passo 29, immagine 2 di 3 Disassembling Samsung NX3000: passo 29, immagine 3 di 3
    • To remove the metal shield on the back case, remove the following screws:
    • Five black 4.2 mm Phillips screws .
    • Four silver 5.3 mm Phillips screws.
  30. Disassembling Samsung NX3000: passo 30, immagine 1 di 3 Disassembling Samsung NX3000: passo 30, immagine 2 di 3 Disassembling Samsung NX3000: passo 30, immagine 3 di 3
    • Use the pointed end of a spudger to remove the ribbon cable attaching the button panel to the back case.
    • Remove the button panel.
  31. Disassembling Samsung NX3000: passo 31, immagine 1 di 2 Disassembling Samsung NX3000: passo 31, immagine 2 di 2
    • Use a spudger to peel back the LCD ribbon from the back case.
    • The ribbon is held in place by adhesive.
  32. Disassembling Samsung NX3000: passo 32, immagine 1 di 2 Disassembling Samsung NX3000: passo 32, immagine 2 di 2
    • Use tweezers to remove the plastic cover on the LCD hinge.
  33. Disassembling Samsung NX3000: passo 33, immagine 1 di 2 Disassembling Samsung NX3000: passo 33, immagine 2 di 2
    • Tilt the LCD so it lays flat against the back case.
    • Wiggle the LCD joints and pull the LCD away from the back case.
  34. Disassembling Samsung NX3000: passo 34, immagine 1 di 1
    • You have successfully disassembled the Samsung NX 3000!
Conclusione
Altre 9 persone hanno completato questa guida.
Kelsea Weber
Membro da: 11/12/15
20.664 Reputazione
32 Guide realizzate
10Commenti sulla guida
Excellent photo documentation.
ernestlaisa - Replica
Thank you ernestliasa!
Kelsea Weber -
Where can I found the camera's microphone?
william_oliveira87 - Replica
Hi dude. I did all the steps and disassembled the camera and I removed the IR filter from the sensor. All is good until that point. And then I assembled the camera in reverse order but now there is no display on screen. In my first attempt I got the menu working but I got no live view display or photo. Then I re-opened and assembled again. This time there is just nothing. Camera turns on but no display, no messages. the zoom button, on/off and even the video record button works all well but no display.. Any thoughts on this pls?
PS: This is an excellent tutorial by the way. I must have done smth. wrong, otherwise I had no issues on disassembly.
edayi - Replica
Thanks for the perfect instructions!
I was able to fix “random mode switching” glitch.
Went up to step 16 (skipping steps 12 and 14). Then removed the top panel.
Extracted the scheme and put it into a cup filled with 91% alcohol for 10 minutes. Meantime opened up the plastic part of the mode switcher and applied 2 drops of universal oil. Then took the scheme out of the cup and carefully cleaned it with cotton swabs and alcohol. Sprayed it with cleaning duster. Assembled everything back and so far the glitch is fixed.
Dim - Replica
Excellent, for disarm the lens, error 00?
camera NX 3000.
Thanks
Jorge Cervantes - Replica
Enhorabuena por este magnífico tutorial.
Mi objetivo fue retirar el filtro IR del sensor para poder utilizar la cámara en tomas de astrofotografía.
Seguí los pasos, aunque para mi no fue necesario realizarlos todos. Por ejemplo, las operaciones del objetivo no son necesarias.
Una vez extraído el sensor, es necesario separar el chasis (en plástico negro). También se encuentra el filtro de infrarrojos (un cristal rectangular muy fino y de color verde)
Para ello, hay que utilizar una llave allen 1.5 y retirar 3 tornillos sellados con plástico. Estos tornillos vienen montados con unos muelles.
Antes de realizar esta operación, hay que tener presente en el montaje posterior, que el sensor debe quedar a la misma distancia exacta del chasis antes del desmontarlo.
Un buen truco es contar con las vueltas en cada tornillo para extraerlos (a mí me daban 8 vueltas)
Una vez que se ha separado el texto, se puede retirar el marco que se ha convertido en una junta de goma.
jcgala - Replica
What a useful guide! Thanks…
Tuncay Özışık - Replica
Hi! My camera have a problem during update firmware, now not working. What I can do? please!
joab_fortaleza - Replica
Where's the internal battery located? The one that keeps the internal clock running when the battery's out? My camera resets it all if I take longer than a few seconds, and it's frustrating to have to set it back up again every other time.
Nikki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 62
Tutti i Tempi: 6,932
