Salta al contenuto principale
Disassembling Apple AirPort Extreme Base Station Model A1034
Michael Garcia
Michael Garcia e 8 altri collaboratori
Ultimo aggiornamento il January 10, 2023
10 - 20 minuti
Moderato
Foto Azione
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
This is the beginning process to remove or replace any functional component in the AirPort.
Cosa ti serve
Strumenti
  1. Disassembling Apple AirPort Extreme Base Station Model A1034, Disassembling Apple AirPort Extreme Base Station Model A1034: passo 1, immagine 1 di 1
    • Remove the three 5mm T7 Torx screws from the back panel.
  2. Disassembling Apple AirPort Extreme Base Station Model A1034: passo 2, immagine 1 di 1
    • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
  3. Disassembling Apple AirPort Extreme Base Station Model A1034: passo 3, immagine 1 di 1
    • Separate the bottom and top casings.
  4. Disassembling Apple AirPort Extreme Base Station Model A1034: passo 4, immagine 1 di 2 Disassembling Apple AirPort Extreme Base Station Model A1034: passo 4, immagine 2 di 2
    • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
    • Remove the four screws from the metal casing.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 17-15, Regan Fall 2011 Membro di Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Membri
13 Guide realizzate
1Commento della guida
Whoa, who’d have thought there was a hidden 5mm phillips under the serial number that does the trick? I’ve had this little beauty hanging around for decades, and my six year old started using it as a flying saucer with his lego creations, and it took me three months of pandemic before I picked up my screwdrivers and tried to take it apart so that he could really use it. For now it’s just empty, and he closes some figures in it with a rubber band and flies it around. Someday I’ll get that dremel i’ve wanted and make him some sort of hatch and latch for it, maybe add some lego baseplate bits to it or something, it can join the rebel alliance for reals.
bitfool - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,041
