Salta al contenuto principale
Dell Latitude 3190 Motherboard Replacement
Sean Gherkins
Sean Gherkins e 3 altri collaboratori
Ultimo aggiornamento il January 9, 2025
30 minuti - 1 ora
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If the motherboard in your Dell Latitude 3190 has failed or requires replacement due to damage or performance issues, this guide will walk you through the process step by step. A motherboard replacement can resolve critical problems like hardware failures, system crashes, or the inability to boot, restoring your device’s functionality.
Before starting, ensure the device is fully powered off, unplugged from the charger, and disconnected from any external peripherals. Work in a static-free environment, using an anti-static wrist strap if available, to protect sensitive components. This repair may be necessary if your Dell Latitude 3190 is experiencing system instability (e.g., frequent crashes or errors), has physical damage to the motherboard (e.g., burnt circuits or broken connectors), or requires an upgrade for compatibility with newer components.
The Dell Latitude 3190’s compact design may involve closely packed components, requiring extra care to avoid damaging cables, connectors, or nearby parts during disassembly and reassembly. Additionally, ensure compatibility between the replacement motherboard and your existing components. Follow this guide to complete your motherboard replacement safely and effectively. If you encounter challenges, seek professional assistance.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
  1. Dell Latitude 3190 Motherboard Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Latitude 3190 Motherboard Replacement, Base Cover: passo 1, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Motherboard Replacement: passo 2, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 2, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 2, immagine 3 di 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Motherboard Replacement, Battery: passo 3, immagine 1 di 1
    • Locate the battery.
  4. Dell Latitude 3190 Motherboard Replacement: passo 4, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 4, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Motherboard Replacement: passo 5, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 5, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Motherboard Replacement: passo 6, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 6, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 6, immagine 3 di 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Motherboard Replacement, M.2 SSD: passo 7, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: passo 7, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: passo 7, immagine 3 di 3
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  8. Dell Latitude 3190 Motherboard Replacement: passo 8, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 8, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 8, immagine 3 di 3
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
  9. Dell Latitude 3190 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement, Motherboard: passo 9, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement, Motherboard: passo 9, immagine 3 di 3
    • Remove the motherboard cable by pulling up on the black bar and carefully removing the blue ribbon cable.
    • Disconnect the white speaker cable connector.
  10. Dell Latitude 3190 Motherboard Replacement: passo 10, immagine 1 di 2 Dell Latitude 3190 Motherboard Replacement: passo 10, immagine 2 di 2
    • Using a spudger, disconnect the black power board and audio cable.
    • Disconnect the white coin cell battery cable.
  11. Dell Latitude 3190 Motherboard Replacement: passo 11, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 11, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the 3 mm screw and lift the metal bracket that secures the WLAN card on the system board.
    • Disconnect the black and white WLAN cables.
  12. Dell Latitude 3190 Motherboard Replacement: passo 12, immagine 1 di 2 Dell Latitude 3190 Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove the screw that secures the camera cable to the system board.
    • Disconnect camera cable.
    • Disconnect the black sensor cable.
  13. Dell Latitude 3190 Motherboard Replacement: passo 13, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 13, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 13, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the two 3 mm screws from the metal bracket on the display cable.
    • Lift the metal bracket that secures the display cable on the computer.
    • Disconnect the black display cable using a spudger or pull it out by hand.
  14. Dell Latitude 3190 Motherboard Replacement: passo 14, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 14, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 14, immagine 3 di 3
    • Disconnect the white power connector.
    • Use the spudger to lift up on black bar to release the trackpad ribbon cable.
    • Pull the blue tab release to the cable from the connector.
  15. Dell Latitude 3190 Motherboard Replacement: passo 15, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 15, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 15, immagine 3 di 3
    • Use a Phillips #0 tp remove the two 3 mm screws on the metal bracket that secures the board.
    • Remove the metal bracket.
  16. Dell Latitude 3190 Motherboard Replacement: passo 16, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 16, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 16, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the five 3 mm screws that secure the motherboard.
  17. Dell Latitude 3190 Motherboard Replacement: passo 17, immagine 1 di 3 Dell Latitude 3190 Motherboard Replacement: passo 17, immagine 2 di 3 Dell Latitude 3190 Motherboard Replacement: passo 17, immagine 3 di 3
    • Carefully lift the motherboard up to remove it from the computer.
    • Make sure not to snag any of the other cables.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sean Gherkins
Membro da: 12/26/17
292 Reputazione
2 Guide realizzate
Gateway, Team 1-5, Saknee Fall 2021 Membro di Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,459
