Salta al contenuto principale
Dell Inspiron 3520 Optical Drive Replacement
Ian
Ian e un altro collaboratore
Ultimo aggiornamento il June 11, 2015
15 minuti
Facile
Introduzione
Vai al passo 1
This repair process includes the removal of small pieces from the computer, therefore you should have a place to store all the small removable screws. This will make the repair process quicker and easier.
Cosa ti serve
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron 3520 Optical Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron 3520 Optical Drive Replacement: passo 2, immagine 3 di 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, immagine 1 di 2 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, immagine 2 di 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: passo 5, immagine 1 di 2 Dell Inspiron 3520 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, immagine 1 di 2 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, immagine 2 di 2
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: passo 7, immagine 1 di 2 Dell Inspiron 3520 Optical Drive Replacement: passo 7, immagine 2 di 2
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
Conclusione
Altre 5 persone hanno completato questa guida.
Ian
Membro da: 01/30/15
1.557 Reputazione
5 Guide realizzate
USF Tampa, Team 16-2, Watkins Winter 2015 Membro di USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Membri
5 Guide realizzate
Un commento
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,691
