Dell Inspiron 1545 Computer Processing Unit Replacement
Introduzione
Vai al passo 1This guide will be utilized mainly if your CPU has gone bad and your laptop is essentially nonfunctional.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
Altre 8 persone hanno completato questa guida.
