Salta al contenuto principale
Dell Inspiron 15 5584 DC Jack Replacement
Sam Vorn
Sam Vorn e 5 altri collaboratori
Ultimo aggiornamento il May 7, 2024
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the DC jack in your Dell Inspiron 15 5584.
The DC jack is a piece of hardware that allows for the intake of charge to your battery, and therefore, power to the rest of your computer. If the DC jack fails, your laptop will not take charge and will eventually lose power, becoming unable to function.
Before using this guide, ensure that the issue is not your charger or wall outlet. Utilize caution when removing the DC jack as it is linked into the motherboard, which is sensitive and easy to damage. Furthermore, ensure your device's battery is drained and your device is shut off.
Cosa ti serve
Strumenti
Mostra di più…
  1. Dell Inspiron 15 5584 DC Jack Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 DC Jack Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 2, immagine 3 di 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 DC Jack Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15 5584 DC Jack Replacement: passo 3, immagine 2 di 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 DC Jack Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15 5584 DC Jack Replacement: passo 4, immagine 2 di 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 DC Jack Replacement, Battery: passo 5, immagine 1 di 2 Dell Inspiron 15 5584 DC Jack Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 DC Jack Replacement: passo 6, immagine 1 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 6, immagine 2 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 6, immagine 3 di 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 DC Jack Replacement, DC Jack: passo 7, immagine 1 di 2 Dell Inspiron 15 5584 DC Jack Replacement, DC Jack: passo 7, immagine 2 di 2
    • Remove the three 6 mm screws holding down the screen hinge in the upper right corner using a JIS #0 screwdriver.
  8. Dell Inspiron 15 5584 DC Jack Replacement: passo 8, immagine 1 di 2 Dell Inspiron 15 5584 DC Jack Replacement: passo 8, immagine 2 di 2
    • Grasp the screen hinge and lift it up.
  9. Dell Inspiron 15 5584 DC Jack Replacement: passo 9, immagine 1 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 9, immagine 2 di 3 Dell Inspiron 15 5584 DC Jack Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Lift up the sticker covering the DC jack connector using tweezers.
    • Using tweezers, detach the motherboard connector and lift the jack out of place.
    • Remove the DC jack from the laptop.
Conclusione
Sam Vorn
Membro da: 03/29/22
977 Reputazione
9 Guide realizzate
Un commento
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,128
