Salta al contenuto principale
DOSS SoundBox Motherboard Replacement
Cassandra Remsing
Cassandra Remsing e 6 altri collaboratori
Ultimo aggiornamento il May 7, 2024
35 minuti
Moderato
Introduzione
Vai al passo 1
This guide shows the necessary steps for removing the mother board from a DOSS SoundBox.
This motherboard controls the connection between Bluetooth and Auxiliary devices so signals transmitted by Bluetooth or Auxiliary can be processed and played over the loudspeakers. If the motherboard fails in the DOSS SoundBox, diagnostic symptoms can include static, intermittent connection issues or failure to play music.
Minimal knowledge is required for soldering as uninstalling the motherboard requires two contacts to be unsoldered.
There is also some adhesive holding the motherboard in place, so caution is recommended during removal to prevent breaks or cracks.
Cosa ti serve
Strumenti
Mostra di più…
  1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, immagine 1 di 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, immagine 2 di 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, immagine 3 di 3
    • Use a small plastic opening tool to gently lift the side of the grille.
    • Gently slide the tool to the front of the speaker.
    • Repeat the process on the bottom of the grille.
    • Gently pull the grille off of the speaker enclosure.
    • Pry with caution, for the grille is fragile.
    Where do you get board replacement?
    mannkettle - Replica
    Before you actually do as this guide suggests, I suggest even more so to read the whole guide first and make certain that there aren’t any superfluous steps that you can skip rather that doing unnecessary steps that will involve an element of risk of damaging your speaker. There’s always a risk of damaging whatever you are working on trying to fix, so unnecessary steps should be avoided, always. With that idea in mind, if what you’re in need of is a motherboard replacement, then please put down the screwdriver, you’ll need to search the web for a replacement, and it doesn’t seem like iFixit, or the author(s) of this guide are any help in that regard. There’s no link, no site name, store name, nothing. So, before you completely disassemble your speaker, as this guide suggests, and lose parts trying to store them loose while waiting for EBay to ship your replacement, buy the replacement first.
    Thousand Sunny - Replica
  2. DOSS SoundBox Motherboard Replacement, Speaker: passo 2, immagine 1 di 2 DOSS SoundBox Motherboard Replacement, Speaker: passo 2, immagine 2 di 2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  3. DOSS SoundBox Motherboard Replacement: passo 3, immagine 1 di 2 DOSS SoundBox Motherboard Replacement: passo 3, immagine 2 di 2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  4. DOSS SoundBox Motherboard Replacement: passo 4, immagine 1 di 2 DOSS SoundBox Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
    Try to not melt your speaker with the shaft of the soldering iron like the person in the picture is doing…ouch!
  5. DOSS SoundBox Motherboard Replacement, Battery: passo 5, immagine 1 di 2 DOSS SoundBox Motherboard Replacement, Battery: passo 5, immagine 2 di 2
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
    Wait, wait, wait!… Were the previous 4 steps even necessary or are you suggesting we take the same trial and error exploratory approach to this that the author seems to have instead of just going for what has already been determined (through said trial and error exploration) as the proper ingress point for a motherboard replacement…the bottom plate?
  6. DOSS SoundBox Motherboard Replacement: passo 6, immagine 1 di 2 DOSS SoundBox Motherboard Replacement: passo 6, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
    And remove the bottom plate…:P
  7. DOSS SoundBox Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
  8. DOSS SoundBox Motherboard Replacement: passo 8, immagine 1 di 1
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
    Thank you. It's 2023 and I needed to get my speaker up and running again.
    Big Kev - Replica
  9. DOSS SoundBox Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
    • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
    • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
    • Be sure not to apply excessive force on the ribbon connector, as it can break.
    • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
    Wait, wait, wait! …again! Why aren’t we disconnecting the battery? That’s supposed to be THE FIRST THING you do when you’re doing any internal repairs on electronics, once you have access to it. Since this is a motherboard repair guide…DISCONNECT THE BATTERY!! Do not start disconnecting other connectors while the board is still receiving power from the battery! Sparks! Shocks! Damaged components…etc! Disconnect the battery first, always!
    Making sure nobody else misunderstands “…don’t remove the battery,” as “Don’t disconnect the battery.” Yes, Disconnect…No, remove. My bad. It’s just that, “remove the battery” was never actually said in this guide, so doing everything up until removing the battery came across as “everything up to …” what actually was said, which was disconnecting the battery.
    Thousand Sunny -
    Ifixit!!! Why can’t you give us more time to edit our comments? Disqus gives 7 days, but iFixit gives a whopping 5 minutes. 5 minutes?! Seriously, I fart longer than that.
    Thousand Sunny -
    Not only does iFixit not offer a way to edit comments after 5 minutes, but even if you do catch a typo and begin editing within 5 min., if you don’t complete the edit within the same time frame, 5 min., then it’ll be rejected and the edit can’t take place. That is stupid on top of stupid. A stupid sandwich.
    Thousand Sunny -
    So, I guess since we’re disconnecting the speakers at the board, the first 4 steps really were unnecessary after all. Huh. I hope nobody needing motherboard work accidentally messed up their speaker with their hot soldering iron unnecessarily, but I’m sure someone did somewhere.
  10. DOSS SoundBox Motherboard Replacement: passo 10, immagine 1 di 2 DOSS SoundBox Motherboard Replacement: passo 10, immagine 2 di 2
    • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
  11. DOSS SoundBox Motherboard Replacement: passo 11, immagine 1 di 3 DOSS SoundBox Motherboard Replacement: passo 11, immagine 2 di 3 DOSS SoundBox Motherboard Replacement: passo 11, immagine 3 di 3
    • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
    • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
    • Using your fingers, you can now remove the motherboard.
    I’m sorry, I was under the impression that this was a motherboard replacement guide, but I guess it’s a mislabeled full tear down guide…?
Conclusione
6Commenti sulla guida
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - Replica
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - Replica
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - Replica
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - Replica
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - Replica
Gostaria de saber como posso comprar os auto falante para minha DOSS, Moro em cotia São Paulo
Arq.Miguel Tomaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 5,401
