Salta al contenuto principale
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
Timothy Lo
Timothy Lo e un altro collaboratore
Ultimo aggiornamento il September 14, 2024
20 - 30 minuti
Difficile
Passi mancanti
Inconveniente Markup
Introduzione
Vai al passo 1
For sticky cold/hold buttons, you may only need to clean the button. This guide will show you how to fully remove and replace the button.
Note: This guide requires soldering skills. If you don't know how to solder or want to brush up on your skills check out this handy tutorial.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, immagine 1 di 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, immagine 2 di 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 1 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 2 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 3 di 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, immagine 1 di 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, immagine 2 di 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 1 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 2 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 3 di 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: passo 6, immagine 1 di 1
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 7, immagine 1 di 1
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
Conclusione
Altre 2 persone hanno completato questa guida.
Timothy Lo
Membro da: 04/22/14
1.172 Reputazione
7 Guide realizzate
Cal Poly, Team 10-58, Amido Spring 2014 Membro di Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Membri
14 Guide realizzate
2Commenti sulla guida
so where do you buy parts???
akatser1 - Replica
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 4,703
