Salta al contenuto principale
Casio LK-170 Speaker Replacement
Samantha Baker
Samantha Baker e 3 altri collaboratori
Ultimo aggiornamento il March 30, 2017
40 - 50 minuti
Difficile
Introduzione
Vai al passo 1
To properly hear the gorgeous notes played from the keys, the replacement for the speaker(s) of the keyboard will take a bit of time as you need a screwdriver and soldering iron. Note that these instructions are to replace the left speaker, but the same steps can be taken to replace the right speaker.
  1. Casio LK-170 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Casio LK-170 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Casio LK-170 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
    • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
    • Three of these seven screws are slightly hidden and may be hard to find.
  2. Casio LK-170 Speaker Replacement: passo 2, immagine 1 di 2 Casio LK-170 Speaker Replacement: passo 2, immagine 2 di 2
    • Gently remove the speaker and its compartment from the front of the keyboard.
  3. Casio LK-170 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
  4. Casio LK-170 Speaker Replacement: passo 4, immagine 1 di 2 Casio LK-170 Speaker Replacement: passo 4, immagine 2 di 2
    • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
    • Desolder the metal that attaches the blue and white wires to the speaker.
    • Remove the speaker.
Conclusione
Cal Poly, Team 13-2, Banghart Winter 2017 Membro di Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Membri
5 Guide realizzate
Un commento
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 727
