Salta al contenuto principale
Casio CTK-501 LCD Screen Replacement
Jimmy Winne
Jimmy Winne e 6 altri collaboratori
Ultimo aggiornamento il 20 feb 2024
15 - 20 minuti
Moderato
Passi mancanti
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
At some point during the use of your Casio CTK-501, you might encounter a time where the LCD screen starts to malfunction or in some cases just stop working. With this guide we will help you get to the screen, and show you how to replace it so that the screen can work like new.
For this repair you will need a total of two things, a #2 Phillips head screwdriver, and two pieces of tape. If you're not sure if you have the right tools or if you're not sure where to get them, the links to both the tape and screwdriver have been provided.
Before starting on this guide, check again to see if the screen is working or not, power it on and off a couple times, and make sure it's connected to a power source. If the problem still persists and the screen isn't working, you can continue with the guide, but check and be sure that the device is completely powered off before starting to take it apart.
Cosa ti serve
Strumenti
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 LCD Screen Replacement: passo 3, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Completely unscrew and remove all six of the screws on the central circuit board.
  5. Casio CTK-501 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of your way.
  6. Casio CTK-501 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove tape from the LCD screen and remove the screen completely.
  7. Casio CTK-501 LCD Screen Replacement: passo 7, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Replace the LCD screen and tape it down to the top cover.
    O display do ctk 501 esta a venda? chama no whats 11 973620565
    Denis Novak - Replica
  8. Casio CTK-501 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Jimmy Winne
Membro da: 10/04/12
578 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
3Commenti sulla guida
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Replica
Hi. Would this screen work for CTK 481?
José Saldaña - Replica
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,318
