Salta al contenuto principale
Casing and Trigger
Casing and Trigger
John Wisthoff
John Wisthoff e 4 altri collaboratori
Ultimo aggiornamento il October 19, 2022
10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to disassemble the Casing of the Fellowes T7CM paper shredder.
Cosa ti serve
Strumenti
  1. Casing and Trigger, Fellowes T7CM Casing and Trigger Replacement: passo 1, immagine 1 di 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Casing and Trigger: passo 2, immagine 1 di 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    The FIFTH screw is under the paper lable
    dontabb - Replica
  3. Casing and Trigger: passo 3, immagine 1 di 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Casing and Trigger: passo 4, immagine 1 di 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
Conclusione
Altre 4 persone hanno completato questa guida.
John Wisthoff
Membro da: 10/12/16
487 Reputazione
3 Guide realizzate
IUPUI, Team 2-2, Baechle Fall 2016 Membro di IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membri
16 Guide realizzate
2Commenti sulla guida
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
Deanna Jack - Replica
Where can i buy replacement gears for this shredder?
indymoon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 4,145
