Salta al contenuto principale
Canon Powershot A610 Speaker Replacement
Matthew Ramirez
Matthew Ramirez e 8 altri collaboratori
Ultimo aggiornamento il July 6, 2023
45 minuti - 1 ora
Difficile
Prerequisite Mancanti
Introduzione
Vai al passo 1
This guide will help you remove and replace your Canon Powershot A610 speaker, bringing back the ability for your camera to use the Sound Memo Function and shutter effects again as long as that was the only underlying issue.
Before beginning this repair, power off the camera, disconnect from the power adapter, and remove the battery.
This repair requires soldering so if you're not experienced, ask for assistance and take a look at the How to Solder and Desolder Connections for more information.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: passo 3, immagine 1 di 1
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: passo 4, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 4, immagine 2 di 2
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: passo 5, immagine 1 di 1
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: passo 6, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 6, immagine 2 di 2
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: passo 7, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 7, immagine 2 di 2
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: passo 9, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 9, immagine 2 di 2
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: passo 10, immagine 1 di 1
    • Desolder the speaker at the two solder points and reattach the new speaker.
Conclusione
Cal Poly, Team 11-26, Maness Winter 2011 Membro di Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,955
